One time while I was jump starting a tractor from my truck my radio shot to full volume and kept returning to full volume immediately after I turned it down.  Restarting the truck didn't help.  Disconnecting the battery fixed it.  I attributed it to the voltage being thrown off when I was connecting or disconnecting the jumper cables.
4 hours ago, ram1067 said:
doubt it......
Don't know it the truck we are discussing has the wheel buttons, and don't know if it is the problem, but there are discussions about wheel button problems on other forums...
  • 1 month later...
Got the same problem with my 2015 GMC Sierra 1500 this evening - the radio volume went up to full volume be itself (same as "ram1067"). The mute function only worked once. The power off function works (i.e., it turns the radio off) but just temporarily. Turning the ignition and opening the driver side door does not help. The high volume makes the truck undrivable.
... appreciate a solution.
Edited by nordiskskier
added text to clarify.
  • 6 months later...
On 11/28/2017 at 6:24 AM, ram1067 said:
Well i fired up the truck this morning and my radio was as high as it would go. I turned the knob down quickly and it went down but then right back up........
WTF i could only mute it. Is there a fix for this? truck going in soon for first service.
That happened to me today!    Any update on how to fix this issue?
  • 4 weeks later...
This happened to me today. Wtf!!!
Sent from my SM-G965U using Tapatalk
  • 4 months later...
I just had this issue occur this morning. There's some theory elsewhere (other GM car forums) that it has something to do with the auto-volume feature, specifically when the heater turns on very high in the vehicle (maybe that it causes the media system to think engine is going very fast and needs to compensate with the volume. This could make sense as for me it happened when it was very cold out, but there have been other days this week that have been colder where this issue was not present.
I was under the impression that the auto-volume feature was an adjustment behind the scenes, so it wouldn't manifest as if the volume were being increased manually (i.e., the volume bar displays and cannot be overridden). This makes me think that it is not auto-volume related.
It almost looks like there's some external input (e.g., a Bluetooth connected phone controlling the volume of the radio by accident?). I think it might have something to do with ice buildup or moisture.
Told my dealer about this at my last visit. They replaced some mystery module 84156701 under warranty. We'll see if it happens again.
This has happened on 2 occasions with my 15' 3500, both times after I had all the doors open for an extended period of time. I had vacuumed an detailed the interior, when finished I
hopped in and started the truck to move it away from the garage and the radio was at full volume.  I assumed I turned it up when cleaning the dash/radio but as fast as I
could turn the knob the the radio volume and volume indicator would climb back to full, turn the key remove and open the door and it turned off. Key back in and on and it was back
to normal.
After that I was very careful detailing the truck around the radio, and it  didn't have the issue for maybe a year, and a few cleanings.
Most recently it happened again after interior detailing, this time I couldn't get it to turn off, key out of the ignition drivers door open. I tried Mute, volume on the steering wheel volume
knob and changing the radio station. It would not stay below full volume, it lasted long enough that I played with every button and turned the key on and off started the eng. stopped
the eng.  and finally went to get tools to disconnect the battery and it stopped when I was walking away, key out and drivers door open. I was terrified driving it for a long time,
wondering when or where id be when the radio would come on full bore. Its been about 6 months without issues.
I really hope m3n00b's dealer is onto something.
Help! On my 2015 GMC Serria the radio display freezes up, and will not respond to push button commends and display  changes to different modes by itself.Turn signals work but no sound, It's been in the shop once but they didn't fix it. It's going back today. Help
to normal.
Next time it happens try holding the power button down on the head unit. That was the only way I could turn it off.
  • 6 months later...
Well, yesterday after driving my 2015 Sierra here and there most of the day I parked to take the dog for her walk. 30 min later I  started it up to cool it off and the radio was full blast, fortunately the dog was still outside. Turned down the volume and it would go right back up again. Radio continued to work with the key out and the door open, I pushed every button at least twice.  Not sure what I did but finally got it off. Now with the dog in the truck all the time I'm afraid to turn the radio on at all. Who knows where/when it will happen again. I called the dealer and he wants to look to see if any codes are present. Other than that  ?.  My appointment is Friday I'll report back what the dealer did. Never in 35 years of driving have I ever witnessed something like this.  Is this a 1 time thing, or has this happened to others multiple times. I'm mostly concerned for my dog..
  • 1 month later...
I have a 2016 Custom Silverado.   My radio control will not allow me to increase my radio volume.  It gets to about 35 them the volume actually starts to go down as I turn the volume up.   Anyone having this issue and if so are you aware of a solution to this?
    • I have an Autel, works great for what it is. Can't do some specific things because you need say the GM tool, VCDS for Audi/Volkswagon and others of course. But those times are few and far between for me.   The other tool I'd like to try one day is the new Topdon scan tools. Seen several video's on them and many youtube people review them.    I've never subscribed for updates or payed to do that stuff on my Autel, so I'm sure I'm missing out on some of the updates but I'm fine with that for now.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
