Ebay Headlights (speed Daddy)
d3m0n
That's really cheap, might be a good candidate for painting to match!
Subscribed to get fitment reviews.
I have.. I ordered and installed the smoked headlights. So far, so good. Fitment was spot on.. can't speak long term yet since I have only had them on for a week now.
11692528_10156001138535495_7637244644529
Nice clean truck!
Sent from Tapatalk App - Samsung S6
These would be something I would consider because I had clear corners on my 98. I haven't really looked, but are the factory turn signal bulbs amber or clear? I ask because I know to be legal with clear corner lenses you need amber bulbs.
The factory bulbs (7443) are clear but an amber bulb (7443NA) or chrome amber blub fixes that with these headlights.
Also, on my set the wires for the parking lights / turn signals were crossed and caused hyperflash. Of course when I call RNA Motoring they told me it was because of LED bulbs I had installed and I would need to purchase cancelors. I had not installed LEDs, just regular ole halogens. I noticed when I locked my truck the bulbs were really dim but when I turned the parking lights on, they were really bright. So I switched the yellow and blue wire in the harness from the new headlights and that fixed the problem. Just a heads up if anyone else runs into that problem, simple fix now.
I ordered these and went ahead to install them, I noticed the harness it came with was giving me errors on dash faulty turn signal, i simply just removed the stock harness and swapped it into the new clear units and boom, works like a charm!!20150709_103714_zpsw7gqy6si.jpg
  • 2 months later...
UPDATE: Do not purchase these headlights. Since the last few weeks leaving for work in the morning and the sun rising later, I realized just how bad these are at casting light. I have the adjuster maxed to raise the beam and cannot see more than 25' in front of the truck. I purchased a set of Eagle Eye projector headlights on Ebay for $375 and are leaps and bounds a better product. I didn't want the orange reflector but it is nice seeing at night.. lessons learned. Wanted to give others a heads up my experience.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 812 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
