2015 silverado 5.3 exhaust
I have talked to the exhaust shop he says to delete the valve and put a magna flow 14 inch muffler on and leave the resonator any suggestions
A friend of mine did the same thing, but I think his MagnaFlow muffler is longer. It sounds really good, and isn't too loud at all.
I have 14" magnaflow with no resonator and flapper removed. Sounds awesome. Good sound when getting on it, barely noticeable while cruising. Do it.
His rumbles at idle, and you can hear it when he gets on it, but it's almost stock quiet he said when cruising down the road.
How does it sound at idle
Sounds good. You can hear it, but its not loud by any means. Nice deep rumble. I'm charging my GoPro up. I've been wanting to make an exhaust video for a while now anyway. I'll make one in a little bit.
I've had flowmaster before and it drones like crazy and V4 was horrible. I've had 18" magnaflow as well. Sounds really good, just not loud enough for my taste. 14" is perfect. Only other one I'd go with is Corsa.
I had the aFe Mach Force XP on my 5.3 and thought it was perfect. Wasnt obnoxiously loud, had a nice deep mellow tone and had almost no V4 drone especially compared to other K2's I've rode in with aftermarket exhaust.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 1 Anonymous, 524 Guests (See full list)
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
