2500hd backfire
2006 wouldn't start used starting fluid turned over would only stay running with thestarting fluid then BOOM big backfire.have fuel pressure at railing 55psi any thoughts?
CHECK FOR CODES!! Starting fluid may work fine on older stuff but I wouldn't go hosing it a newer vehicle if it won't start.
take fuel pressure reading at key on, engine off. iirc 55 psi is the low end of the spec. You definitely have a fuel issue. Suspect the pump is bad
  • 1 month later...
DO NOT EVER USE STARTING FLUID ON ANY PICKUP.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,233 Guests (See full list)
