Any used a P3 -AND- the GM Brake Controller in Current Gen?
As far as I know the hill start assist does work with the controller as well. There will be a delay with the trailer same as the truck. As you try to move forward it will have a thump because the power to the brakes is still on and the once the assist releases it will then release the brakes.
Just to be clear - I wasn't specifically asking if Hill Start Assist operated the same on the trailer as on the truck, although it would seemingly be good to confirm that it does. I was actually trying to understand if the brake controller was continuing to apply voltage to the trailer brakes, even after I removed my foot from the brake pedal similar to how the Hill Start Assist would work even when I'm on flat ground. I'm trying to reason out why the trailer brakes would potentially be hanging up like they do.
Sorry misunderstood... No the voltage output will only stay on as long as you are holding the brake pedal(hill assist aside) On flat ground the brakes should release immediately. If they are still holding then it sounds like you may have a brake or more sticking on the trailer
That's what I'm thinking.
It's a new trailer, but the wheels need to be balanced. So, when I pull them off, I'll look more closely at the brakes to see if I can tell if it's a specific brake that's causing the issue or if it's all of them.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
