Hard for dealer to do alignment after levelling kit?
SRoy
Installed a rough country 2" levelling kit(keys) on my 2015 silverado hd last night. Drove to the dealer today for service and spent the afternoon there waiting. From what I have read I was understanding it wasn't a major alignment and in most cases just a toe in basically. They had it on the hoist for over 3 hours and keeping it over night because it now plus to the right? I drove 20 miles to the dealer and it drove perfect. Although I know long term would have wrecked the tires.
Kind of doubting the skills of the alignment tech at the moment.
When this is done I want to purchase the bilstein shocks for it. Does anyone know what shocks for the 2" level that go on the front?
Take it to a better shop with a Hunter laser alignment machine. They'll get it set straight no problem.
Will see what they have tomorrow for a machine.
Keys?
Oh, never mind.... I just caught that it was HD
Ive installed tons of these kits and it takes about 5 mins to do the alignment.
Find a new dealer. My dealership took 20-30 mins to complete, and that time started even I gave them my keys.
Thank you for the replies. This really has me bothered that my dealer can't perform this what seems to be like a simple task. Feel that I should be taking it to a professional even after they hand back my truck keys. Sorry if I posted this in the wrong section being a HD I didn't realize.
I am a GM trained mechanic from years ago and have some knowledge mechanically but haven't installed a kit before myself so wasn't sure what should be involved except from that I have read numerous threads saying the alignment is just a quick touch up of adjustments.....not a full shift for an experienced alignment tech. For myself I could see taking 4 hours as I haven't performed an alignment in about 15 years but the alignment machines are way better now and the components of the suspension are essentially the same.
Picked up the truck today and well have to say I am not very impressed with the dealer overall.
When they called to say it was ready I had to ask if they did the tire rotate as well which they didn't. I said you don't check the required service maintenance? So they did the rotate after the alignment now. I am sure its not an issue but would have been nice to have it done before the alignment. They adjusted tire pressure and all 4 are the same now which is all good going by the vehicle status but off the recommended pressures really.
They use ExpressAlign from the report. Truck looks awesome but pulls to the right. Billed me an hour flat rate which I am somewhat happy with but going to be looking for a qualified shop to align it today. Hope I get a service satisfaction questionnaire for this from GM.
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 417 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
