Side mirrors automatic in
Hello,
I cant seem to find this in the owner manual.
Is there any way to setup my side mirrors to automatically tuck in when I turn off the vehicle?
Fondupot's video
This is what I did in order to setup for use with key FOB. Some vehicles have the options for this and others do not. Not sure if there is an auto feature though, would have to go out and look later.
If you hold the lock button on the remote for 3 seconds, they should fold in.
Not sure if they can be set to auto-fold on power off.
GM calls it AUTO, but is not auto. If you enable the setting, they will move when you command them to move by holding the lock/unlock button on your remote. They're electric, not manual and not Auto.
Only way to do it is with the FOB or the actual button in the cab. There is no "auto" setting. Maybe in 2016....
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 983 Guests (See full list)
