truck does not drive straight anymore...
I tell yeah this is getting really annoying and its gotten to the point where i do NOT want to highway drive anymore... someone mentioned it could be this...
Tramlining: Coping with the Ruts in the Road
it could be that? but this issue im feeling is 100x worse. my truck has a 4" fabtech suspension lift with the Uni ball UCA.
on highway my driving is constant swerving back and fourth the truck hits a groove in the road and just dives into it! its annoying the truck slightly pulls left as well. When i got the arms installed i got a alignment right after it. And no problems were said. This is a bad issue and like i said ...i don't even want to drive on the highway! also i mostly feel it at 90KM + i dont want to wast money and get another alignment for no reason...maybe it could be a balancing issue? maybe i need an alignment NO IDEA! im no mechanic either so im stumped on what this could be :( i'd really appreciate your guy's information on this.
Thank you.
You describe an alignment issue. I would first verify all my parts are tight and then check air pressure in tires. After that I would take it somewhere other than who originally did an alignment and have it fixed.
You need a proper alignment done by a qualified tech. Sounds like a TOE issue from what you are describing.
Take it somewhere with a reputation for good alignments.
I agree. Alignment.
I'll bet the wheels are toe'd out. Very easy to check toe setting. Jack the front wheels off the ground, spin the tire and scratch a consistent line on the tread all the way around by holding your hand steady near the ground. Do it on both tires. Set the truck back down. Drive it and park again. Have a friend help you measure as far up the tire as you can while keeping the tape measure straight, both front and back of the tires. The front side of the tires should be closer together (toe in) by about 1/8" or thereabouts.
I agree. Alignment.
thankyou guys so much so i should really just get an alignment and mention about the toe being out.?
Yes. A good alignment shop will listen to you describe your problem and likely test drive it to verify the issue. I think your issue may be a simple one....the shop that aligned it last maligned it. Or misaligned it. That would be a simple fix.
All of these responses are correct. It sounds like alignment to me also. Have another shop check it and I'll bet it's off. Ask to see it while it on the alignment rack. I always pull people out of the waitng room to show them. Some techs are different then others.
Make sure you get a shop with GOOD equipment and GOOD technicians. Typically the Hunter brand laser alignment machines are the best. But it also takes a good alignment technician to get it right.
While newer, better equipment is always good, I have a shop I've been going to for 40+ years that uses old style trammels and gauges. They run production class race cars and do alignments for racers in the L.A. area. Good mechanics at this shop make the difference.
I recall when I was in my late teens or early 20s, I borrowed my brother's 1975 4x4 Silverado to go on a out of state hunt trip with a friend. My brother had just put tires on it and he instructed me to get it aligned before I left. The day was hectic. The 'good alignment shop' was booked. So I took it to a Mark C Bloom tire store for an alignment. I mean, c'mon, what's to align on a solid axle 4x4 other than toe? One simple adjustment of the tierod. Right? I watched this bozo fart around for nearly an hour on the truck. He clearly didn't have a clue what he was doing. I'd watched my good shop many times and knew the drill. We got out of there, drove to my house, jacked it, scribed the tires and measured the toe. It had a 1/2" of toe out. I adjusted the tierod and got the correct toe in and we were on our way. It took me maybe 10 minutes for that.
amazing responses! i go in tomorrow and decided to go with the dealer ship to get it done! very nice people as well. 89$+ tax. I will be mentioning that im possibly toe'd out? correct ? :P
Just mention that you want an alignment and what the truck is doing exactly.
No need to mention toe in or toe out, or camber, or caster. When they put it on the rack, a good tech will immediately see what the problem is.
They should take it for a test drive before and after the alignment as well.
  • 3 weeks later...
so i went to the dealer to get it fixed and it was toed out a bit but nothing to drastic for the truck to do that..the guy said they drove it and it was fine obviously....i didnt have much time to actually highway drive it until today ...it was JUST HORRIBLE! im constantly just steering and jolting right left because my truck just will randomly go left slightly...then ill fix my self..then go right slightly.....dont even ask me to pass a vehicle...its like im getting struck by massive 100km winds! its insane! unable to drive on highway...so i called them and freaked and they said it might be my steering collum or something/ :$ whatever its going in on monday!!!
Does it seem to move after hitting bumps? Could be a steering stabilizer issue.
Go back to the dealer and have them ride with you on the highway. Then, just to be fair, let them drive with you in the passenger seat just to make sure it does the same thing.
yes a bump will nock it right or left usually ....its annoying and i feel like my steering wheel is not stiff like its just has too much give....tbh i have no idea ! just i payed 60,00$ for my truck and it can barly drive? like what the heck
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
