Another noob from TX
Jernik
Been lurking for a few weeks, gathering info before finalizing my purchase. This looks to be another great auto forum (I've also been on a Jeep, Ram, and Infinity forum under a different handle, and currently a 4Runner forum with my current ID).
Anyway, just picked up a 2015 Sierra Double cab 4x4 this weekend. Really glad I stumbled on the "tricks and tips" thread, it helped immensely when setting everything up to my liking. :thumbs:
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
