Clanking noise from under bed of truck
Truckmed13
Hi everyone a couple of weeks I noticed my 2014 Sierra Denali had a clanking noise coming from the back of the truck whenever I went over bumps or sometimes when turning. I took in to the dealer so they could take a look at it. It's been there 3 days and they called today saying that this is normal for the 2014 sierras. I told them I've had this truck for a year already and have never experienced this problem until recently. They said they would look again to see if they missed anything.
Any ideas? Anyone else experience this problem?
Yes I have had my 2014 Sierra Z71 4x4 in for the noise. They said it was the leaf springs, and is pretty common for these trucks. The authorized fix by GM is to grease the pads between the leaf springs. Well they did that to mine and I went on a long road trip and after about 900 miles the noise was back. and really noisy once I drove through rain. I reported this back to the dealer and he said that was the only fix, there was no other solution. Replacing the springs would not solve it. It would do it with the new springs. They suggested that I have the leaf springs greased every time I had an oil change. I couldn't help but laugh. I asked him to show me that maintenance item in my owners manual. I am not accepting that solution, I am on a letter writing campaign to GM corporate about this. The dealer told me that if enough people wrote GM complaining about this issue that they would eventually do something about it.
So if you take yours in, would be interested to know what they tell you.
Thanks for the reply guys. I'll tell them about the leaf springs but this sucks a truck this expensive/ new should not have this problem with the only solution being the grease the leaf springs!!
I have a 2015 chevy and mine is in the shop for the same reason, the leaf spring pads on these trucks are terrible. i am driving a 2015 loaner with only 3k on it and it does the same thing. Mine is just lot louder. pretty bad that a brand new truck sounds like it has 400k miles on it. all the little stuff really adds up on these truck- they should never have been released till they had all there issues worked out, i will not consider gm vehicles again they are just not even comparable to the last tundras i have had.
    • Congratulations Isttype, on your gmc. Really like my 2024 2500hd sle doublecab now with 85,500 miles.  I checked the oil today at 4800 miles since last oil change and barely reading on the stick.  I don't care if GM says it's Acceptable adding a quart every 2000 miles because that is 100% BS, It is not a 1966 Harley Shovelhead! Sounds like it's setting up a future failure like I had with my 1500 6.2l. Other than oil consumption problems, I really like the 6.6l gas and 10 speed is really nice.  Towed a light 4000 pound trailer last week and averaged 14 mpg.  I was pretty impressive that a 7300 pound gas truck did 14mpg towing, Later-
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • I don't think you will need a split, separate product, etc., the OBD port should be able to deliver everything you need. Since your device would be plugged into it all the time, it wouldn't miss anything.    Hardware in this case will be the easiest part of your project - ELM 327 devices will already deliver all the data you need. Reporting/software is where your advantage/marketability is.
    • I do too. I’ll never be stuck again 😂
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
