I'm having the same issue. Iss and bearing have both been replaced and the problem is still there. Its clearly a loose part just behind the steering wheel. I've been searching online for two weeks and the closest I've come to any explanation at all is in the link below. I just found it this morning and haven't tried it yet. Will update this weekend with my findings. Good luck.
  • 1 year later...
Wondering what was the procedure to jack off my steering shaft,I have 2006 GMC Sierra. I KNOW it isn't a safety concern,I just don't want to hear it anymore,too busy listening to make sure drive shaft doesnt fall off again( totally my fault) i digress,how EXACTLY is it fixed? Have adequate experience in abusing myself so this proces should be an easy fix.
  • 5 months later...
I just wanted to get this on the net somewhere, because nothing I read was the solution for my 2011 3500. The slop I found is in the upper column, between the steering wheel and ISS. Between the ISS and the steering wheel is a collapseable section of shaft and the outer doesn't fit the inner perfect, so it has some "slop" in it.
I pulled the column(really easy actually) and disassembled it to get the upper shaft out. Then I used a punch and hammer to "stake" the outer tube of the telescopic section. I put one good dimple in the curved surface of the tube at at each end of the slip section. That took all of the slop out. I figure it was enough to get rid of the rattle, but not so much that it would prevent it from collapsing in a crash. I got it all back together and my rattle was gone.
Some of that is probably a little confusing if you've never been in there to look at it, but if you do go in I think you'll see what I mean.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
