BFG 275/60/20 users: input needed
Prong
Later today or Wednesday, I should be picking up my 2015 Silvy 1500 max tow. I already have a Motofab 2" level kit to go on it. I've searched this forum and can't find a definitive answer. The truck will have the factory molded black splash guards. Will the 2" level clear these tires and not hit the splash guards as well? No rubbing? My aim is to hit Discount Tire as soon as the level goes on and the alignment gets done.
I have a Sierra 1500 with the max two and the 275/60 BFG's fit fine a the stock height. Ran it like that for a few weeks before my 2" level.
I would go with the 275/65's if I could do it again.
Youll be all set. I had 275-60-20s on until I could get my truck in for a level, no issues at all. There was even room to spare, you could fit 34s I bet.
I've put 275/60 20's on stock height trucks with no issues. I'd imagine with the lift it should be fine.
My 2010 Silverado 1500 came with 265 70 17and I just last week put BFGoodrich Ko2, 275 55r20 and new 20inch rockstar2. Circumference is the same but the jump from 265 to 275 made them barely rub in the front on a tight turn. I have now put a 2.25 ReadyLift on the front and it's now perfect. I did nothing to the back end and the back is still 1inch higher than the front wheel well. I know 2015 is the thread so sorry in advance.
Sent from my LG-D852 using Tapatalk
I'm guessing the offset of your wheels is the issue with rubbing. 275/55/20 is stock size when the truck comes with 20s.
Yes, sorry I forgot to mention the plus 10 offset on the new wheels, you are right about that contributing to the rubbing. Maybe I am out to lunch thinking the width change to 275 was an issue with the rubbing. Anyway sorry to jump in on the 2015 talk. Thanks for the info that stock 2015 is 275.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 743 Guests (See full list)
