Muffler AND resonator delete?
Jbirch
Just a question. Or point me to a thread where this is mentioned? Did anybody do a muffler AND a resonator delete? I've heard the muffler delete and want something a little louder. Straight from the first 2 cats to duals is what I'm interested in. I'm going to get some kind of tune/programmer to disable the AFM.
Thanks in advance fellas
I had my truck just the stock 2 cats then the 3 inch pipe into 2 2.5 inch pipes before the rear axle. no mufflers or resonators or 3rd cat. was incredibly loud. I loved it but driving anymore than 10 minutes it was excessive had to throw my flowmaster super 40 back in. I wouldnt suggest it for a daily driver but its your choice if you want crazy loud go for it
MFleury
How much knowledge and experience do you have with the GM Borla?
Sent from my SG Note 4 on Tapatalk
Ive never looked into them or seen/heard one irl
Thanks man..
deleting the resonator does make a huge difference. i replaced my muffler with a flowmaster super 44 and kept the resonator. drove with it a day and wasnt satisfied as i didnt get the noise i wanted. removed the resonator the next day and BIG difference. really happy with my set up now
Thanks guys I appreciate it! I'm probably gonna try to do that first. When you remove the 3rd cat did it set off any codes?
No it doesnt. there are no sensors behind it its basically just another resonator
So doing this wont throw any codes or void warranty with GM since its past all the sensors correct?
My service manager was told by the mechanic that changed my oil that I had removed the 3rd cat, He mentioned it to me when they were finished and I asked was that a problem and he said no not really and in his mind would not void anything. It does not throw any codes it's not a monitored cat just some California Bullshit!
RT
Thank you, im picking mine up tuesday to buy. Seems like a more performanve based dealer with all the zo6's they have so maybe they will be more leaniant on mods lol
Possibly a video of the final product????Thanks
  • 1 year later...
Did you find with the resonator in it sounded like stock? Or was there just not as much noise as you preferred? I just got the super 44 installed and the shop recommended deleting the resonator, I find it just a little to noisey for my liking, and might get the resonator put in, or another one. Thanks
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
