Existing engine battery 2015 Silverado 1500
Dickiedodo
I just picked up new Silverado and want to install a second battery.
I know about the isolator and required wiring of which is no problem to me.
My concern is wiring into the existing battery on the positive terminal. It appears there is no place to tap my new wiring.
The cover on the battery with the usable links is there a spare? I hav not removed the snap cover for the fuses.
Any advice or if any one has taped into the existing battery would be helpful
Thank you
Dick
Is there a spare post under the cover?
Thank you
Dick
There should be. I know there is on the 2014's.
Spare post but no nut on it. Not knowing the thread size, I just doubled up on one of the populated posts.
just wondering do you live in the artic to need a second battery, these trucks are pretty good starters even in Canada where apparently it gets cold lol
LMAO!!!!
RT
No I don't live in the Artic. I plan to run an 110 volt inverter off the second battery. I will use a Cole hersee battery isolator between the two batteries.
Dick
I plan to use a 750-1000 watt may be a big. But will not use device that draw that much, being on the higher capacity than going to small is better. I realize that the one battery will not give me much time if using a high wattage device.
That is ok as I will not need long running time on a device
I have a motorhome and and use two large inverters but have six batteries. I am familiar with these devices and the correct wiring.
The Silverado has a small inverter and has a 110 out let in the cab but is not sufficient for my application.
I am a photographer and also shoot Astro at night. Many times I am out all night.
Dick
For your information, I have mine setup in parallel with no isolator for months. No issues so far.
I even made my own positive terminal cover and it is spotless when I opened it couple of days ago.
In the answer to the photo question. If your interested the sky and milkyway use a wide angle lens with the widest aperature. I use a 24 mm 1.8 for sky and milkyway.
Next
What did you make the positive terminal cover out of? Can you supply an image of it both on and off the battery?
The reason I will use an isolator because of using the inverter and I can run the battery quite low with out compromising the start battery
Thank you
Dick
Next
Thank you
Dick
You can find the pictures below. I have a plastic soft cup below the clamp connection and the top black cover is made from flange shipping cover, I have added some JB weld to all the seams to make it stronger.
http://www.gm-trucks.com/forums/topic/157013-what-have-you-done-to-your-k2-today/page-242?do=findComment&comment=1628264
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
