Hello from north jersey
kbauer55
Hello I am from north jersey and presently own a 2014 gmc sierra double cab, sonoma red with a leveling kit, it is my 3rd gmc (2001, 2011, 2014). I just want to stay on top of all that go's on with these trucks.
Welcome from nnj as well more specifically bergen County
Sent from my SM-G925V using Tapatalk
So there are a few of us NJ truck guys on here.....lol
Yeah there is a couple of us on here, do you know of any truck shows around new Jersey that are coming up
Were you at diesel nationals a few weeks ago?
Yes I was and it was great, were you able to make it
Yep I was parked with a couple other trucks in the area where the racers park and all the partiers, we were in the first row against the fence next to the track
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 832 Guests (See full list)
