OnStar 4G LTE bleeding data?
I have 13 GB of data on my Verizon plan. Last month we were getting pretty close to the limit and had a road trip scheduled so the day before the trip I purchased the 1 GB plan through OnStar.
Halfway through the trip the music just stopped (2 hr drive). I had also listened to music for approx 45 minutes the day I purchased the plan.
I called customer service because my OnStar app showed that I still had most of that 1GB remaining. They told me that I had burned through the entire GB. They added 500 Mb and escalated my call. The tech guru called me later and reaffirmed that I had burned through a GB and as a courtesy he would reset it for this month.
My issue is that after 6 days of listening to more than 4 hours of music and other smartphone activities with 2 phones I still haven't used an entire GB on my cell plan.
Has anyone else noticed or felt like the built in 4G bleeds data?
When I bought my 15 silverado , I supposedly went through 3GB of data in 3 weeks, I don't even use the phone while driving. I called they escalated it gave me 500 MB. I went thru that driving with my phone off. So now I don't buy any data anymore
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
