Borla GM Exhaust
Tek74
So I picked up a used GM Borla dual rear exit catback off craigslist. Have all the parts and instructions. Issue is I cant tell if it was the right part number with correct length I pipe for my Crew Cab short bed.
Can anyone measure the length of their GM Borla I pipe so I can rule out part numbers?
Thanks,
Josh
  • Replies 51
Thanks,
Josh
I'm kinda misunderstanding you. Do you have a part number for the kit you bought? Or are you trying to figure out what part number you received? You need 19303333.
Sent from my SM-G920R7 using Tapatalk
Hey sorry trying to figure out what part number I have. Only difference in kits is the length of the I-pipe. Box had no part number, instructions listed all part numbers. I got it for 400 so it was worth it no matter what. Worst case Id add some pipe in.
I measured today and my I-pipe is 45.5 inches. I heard back from Borla actually after posting this and they said that I have the right one. Now I just have to find time to get it on.
It pays a half hour of labor so it shouldn't be too hard to install. Good luck. I really enjoy mine.
I would like to get a borla dual exhaust out back and I was wondering if I take it to the shop that they can bend it or not. I've seen some trucks here were the exhaust points back but to the sides and is kinda tucked under the bumper.
Sent from my SM-N900V using Tapatalk
Thanks for the reply. The sport is the one I'm looking for. I just didn't see it specified in the Chevy parts website.
GM borla exhaust is only available in touring. If u want sport, u need 2 go with borla. I have 1 for sale!! Brand new in box, make me an offer if interested.
  • 2 months later...
Yes, borla Exhaust is still for sale. Brand new in the box. Its the sport exhaust for a 6.2 litre engine Yukon Denali. Send me an email.
Thanks.
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
