Tonno Pro cover
RBSilvy85
Hey guys I just bought a TonnoPro trifold cover for my truck. I just have one little problem. I put it on last night and I canmt seem to get the the part of the cover closest to the tailgate to close tightly against the tailgate. I've adjusted the clamps to clamp down as much as possible without breakibg anything but it still seems to leave a little gap between the too of the tailgate and the water stripping on the cover. Has anyone else had this problem, or is there a way to fix this?
If you cant slide the clamps closer to the tailgate get a roll of the black foam seal like you use for doorways and windows and try that.
Sent from my Note 4
It's just the design, you have to tighten the clamps to where it feels like it's going to break when you latch it down and it's still not a good seal. I had two Tonno-Pro trifolds, one of which was a warranty replacement. They're junk, I switched to an Extang Solid Fold.
I got a used one and had this issue. Flip the last panel up, the rail with the clamps are held in by 2 sheet metal screws 1 on each side, unscrew them ,silde the whole bar about 6 to 7" closer to the bed, but make sure the clamps can still grab the bed lip. And zip the screws back into the outer rails. And nice and tight seal afterwards. I initally went 8.5" closer but the clamps wouldent grab bed rails. Play with it before you shoot the screws in. And i dont have my clamps cranked down at all, they are good covers but for some reason that rail is too far back
After reading your response to this thread, I did some homework and watched some reviews on the Extang Tonneau covers. I'm kinda liking the solid folding model. You said you switch from the Tonno-Pro to the Extang, but didn't really offer any feedback on the Extang. Are you 100% happy?
Just wanted to say thanks. I moved the last bracket about 4" and that has sealed the cover to the tailgate. Now im happy and for $250 and $50 rebate I think this is a good deal. May not be as nice as some of the others but it'll do everything I need it to do.
  • 3 weeks later...
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
