I love the rear slider. If you're driving on the highway with the side window(s) open, you sometimes get some weird air pressure issues in the cab.  Open the rear slider lets the air move through the cab freely and gets ride of the noise and pressure issues.
I’ve Got a 2018 Gmc and am on the second leaking sliding rear window. The first time when they were replacing it I asked if it could be done, and was told I couldn’t because it would set off the body controls module?? Can anyone confirm if removing the slider affected anything?? I have never used mine and like the look of the solid wonder better not to mention no leaks is a bonus.
  • 11 months later...
i would like to thank mkwambold for his help replacing my solid glass rear window to a rear glass slider, his instructions & diagrams were just what i needed to complete the job without any issues. Thanks again.
I have a 2021 GMC Sierra crew cab with a solid rear window, want to replace with a sliding power window
How much and where to get it done ?
thanks
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 674 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
