was this to remove the old window and install a new one? if so that seems like a hell of a deal. on the other hand, it's only a $250-$300 option on the sticker so if that's what your talking about, not such a good deal.
Sorry, it was $750 and yes to remove and add.
  • 3 months later...
My truck has the switch for the electrical slider but i dint have the actual sliding glass.
My girls 2014 has it tho. I would never use is to i dont care but i just thought it was interesting that mine has the switch for it but not the glass.
Sent from my Note 4 on Tapashit
I'm another non slider guy. I like the cleaner look and unobstructed view. My last truck had it and the only time I used it was when the kids would open it then complain about it and not be able too shut it.
I love mine. I don't really use during the summer down here (Houston). Way to hot, but in the season we call "winter" I use it all the time. It creates a good air flow on the cooler days. Plus the rear defog is really nice since my truck is often covered in dew in the mornings.
I use mine occasionally when it's warm and the windows are down. I wish it was like the one the Toyota Tundras had where the whole back window goes down into the body. Those are cool.
Anyone know info for something like this?
I got behind a first gen Nissan Titan leaving work today and this looked earily similar.
Fat fingered, and shot from the hip.
  • 1 year later...
I guess I'm the only one that didn't want a power slider.. one of the first mods I did after getting my truck.
hello my name is mike and i`m doing the window swap right now but i ran into a snag could i ask you to take a picture of the right side fuse box on your factory equipped rear power sliding window truck i need to see if i`m missing fuse`s i can be reached at [email protected] or 610-730-2789 thank you so much in advance Mike
Is there a manual slider? Because if really like one for my rc
Yes. CR Laurence makes one and I've really been eyeing it.
  • 6 months later...
OK guys / girls so i tried to do a post the how to install rear power sliding  window the other day and  it  all went south all there is in  my post is the  GM upfitter  wiring diagrams  so ill give it another go i did the power sliding rear window upgrade on my 2016 2500 silverado LTZ duramax crew cab short bed 4x4  now this will seam hard to do but its not  I have found info on the internet  that states  only the higher end models have the rear wiring in place so first thing you need to do is check that only way i know how to do this is pull the rear seats and rubber mat  from the rear of the cab and look on the passengers side mid way up for the wire plug with nothing plugged into  it if its there your set for a fairly easy install now  my truck did not have the weld studs in place for the motor to mount to so this is what i did i installed the power slider with the motor taped to the glass then after it set up i dropped the motor and  lined it up on the mounting boss`s there are 3 raised boss`s on that side just move the motor around  you will see were it  lines up (the motor is attached to the regulator by two push pull cables so it will hang and line just about right up)  i drilled 3 1/4 " holes in the back of the cab (be careful so you don`t  poke the bed its close) then i used 3 14-20" SS bolts with metal rubber sealing washers on the outside and  used   3M  strip calk 08578 to make  3 calk washers to install on the rubber side of the sealing washer to make sure  i have no leaks i put the bolts and  washers in place with a sivitec 323423 flex claw tool and  mounted the motor and plugged it  in done  back there for now  moving to the overhead console open the glass`s holder and insert your hand in between the front  of the glass`s holder and the console and  pull down the hole section were the led`s and the switches will pop down look up inside the back portion of the console and you will see two torx pull them out  then go to the front of the console  grab the two sides and  pull down there are two spring  clips holding it in there so you need to pull a bit drop it  down and  go to the main harness plug and  detach it  no the plug left  up there is the (X316 headliner harness to console plug)   your going to add 3 wires to this plug ill get to that in a bit you do not  need to drop the headliner there is  plenty  rum to feed your new 3 wire  harness you are going to make in the front  of the headliner you do need to pull the drivers side pillar post cover do this by popping out the two small plastic screw covers on the grab handle  and then pull the two screws remove grab handle the pillar cover is held in by spring  clips im going to list  the wires you need to add now  and wear they  come from and go to this is easy make your harness with the overhead wire ends installed and  let the other ends blank for now
first  wire is going to be the power wire  from the driver side fuse block (X51L) fuse block instrument  panel left to the  overhead console truck harness plug (X316)   pull the X51L block out its held in by retaining clips very easy to pull  look on the back side for the X3 plug pop it out  and  find pin# 11 install your wire with proper GM terminal end in there make sure you have the tang on the  terminal end facing the right way look at the others to see how its installed  run this wire up to the overhead X316 overhead console plug and find pin#23 add this to that  location
next wire is going to be the closed signal wire  this wire comes from the X61A  junction block  this is the box under the dash behind the brake pedal next to the E brake  you have to pop the cover off it  find the X3 pin plug unplug it  and  install your wire end  into  pin # 26 run this wire up to X316  overhead  console truck harness pin #20
next will be  the  open signal wire from the X61A junction block  this is the box under the dash behind the brake pedal next to the E brake in the same  X3 pin plug find pin #32 install your pin and run this wire up to  X316  and  install into pin# 19
THINGS YOU NEED TO INSTALL
1. rear power sliding  window with regulator and  motor
2. the proper overhead console with rear slider switch in it  (order with all the options in your overhead console now and then add power slider to it) THERE ARE MANY
3. passenger side fuse box
4. two lower trim panels under power sliding  window (old ones will not fit)  or cut
5. 20 - 25 foot of wire GM terminal wire ends that fit the plugs and fuse box  3 - 1/4--20" bolts sealing flat washers and  nuts
I DID THIS INSTALL CHEAP  I GOT ALL MY  PARTS FROM A SALVAGE YARD EVERYTHING  FOR 400.00 IT DID TAKE ME A BIT TO UNDERSTAND  THE GM UPFITTER WIRE DIAGRAM BUT ALL THE HARD WORK IS DONE FOR YOU JUST FOLLOW THE UPFITTER PLUG AND PIN LOCATIONS I HAVE ATTACHED AND  MY INSTRUCTIONS
IF YOU NEED MORE HELP OR ADVISE EMAIL [email protected] /CALL/TEXT  610-730-2789  leave a VM  JUST SO YOU ALL KNOW IM NO ELECTRICAL GUY I SUCK AT IT BUT I MADE MY WAY THROUGH THIS WITH LITTLE TROUBLE ALSO KNOW  DO THIS AT YOUR OWN RISK I WILL NOT BE HELD ACCOUNTABLE FOR WIRE FIRES WRONG INSTALL OR DUMB MISTAKES GOOD LUCK
FED WHITE BOL01192018.pdf
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
