Towing recommendations, questions.
I've got a 1998 Chevrolet 1500 Express, 1/2 ton , 5.7 liter engine. I took my Trabant to a car show in DC this past weekend. The van did great (hit 138,000 miles on the way back to Tennessee) but as you can see in the photos, the rear end is squatted more than I think it should.
I think some of it has to do with the design of the U-haul trailer. Although I secured the car with some ratchet straps I used the ones that wrap around the front wheels of the car. So this threw some of the weight of the car toward the front instead of the axles on the trailer. I believe if I centered the car on the wagon, it would have taken some of the weight off the tongue.
My question is if I installed some air shocks would this help?
I installed the biggest rear swaybar on the back Addco had to offer and this made the van more stable at highway speeds.
I considered installing some 1 ton leaf springs in the rear but that might be overkill.
My other question is this van is listed as a 1500 Express. I found some air shocks on Ebay for a 2500 Express. Dumb question but GM's truck designation has always baffled me. I'm assuming a 1500 is a 1/2 ton and a 2500 is a ton or 3/4 ton?
Would the air shocks make any difference? I mean no matter wheather the van is a half ton or a full ton, wouldn't the same shocks fit either?
IMG_20151109_085256082_HDR_zpsuqqu2lcf.j
1500 is considered 1/2 ton, 2500 3/4 ton.
Couldn't tell you if shocks would be interchangeable or not.
No doubt, that's not a very safe setup as it sits.
Ideally you want 10-15% of the total trailer weight on the ball. It's more than just how it looks.
Keep in mind that those Van Conversion Companies ordered the cheapest units that they could to maximize their profit. Then add their decals and accessories and etc. Now if you are going to do a lot of towing I would put heavier springs or at least helper springs on it. Shocks are a matter of choice. But i would get a Weight Distribution Hitch. That way you can keep everything on a level plane when towing. This will give you starting point to research if you think you might want to go that way.
http://www.reesehitches.com/product_categories/weight_distribution_hitch?gclid=CJffndnGiMkCFY-VfgoddL4Ctw
Yeah you would think as much stuff these conversion companies add onto these cargo vans, they would have ordered a ton or at least a 3/4 ton to compensate for the extra weight. Especially as much as they cost when new.
Dad had a 90s Ford F350 15 passenger van. It had a higher center of gravity but was a ton and was much more stable on the highway.
Monroe does not seem to off their Max-Air shocks in a 1/2 ton (1500) but Gabriel does offer air shocks for the 1/2 ton.
http://www.summitracing.com/parts/gab-49231/applications/make/chevrolet/model/express-1500
So if I added air shocks to raise the rear end when towing, would this be just as good as installing 3/4 ton or 1 ton springs?
The van's 5.7 liter engine pulled the car and trailer just fine so I don't think I exceeded the towing capacity. I don't know the weight of the trailer but my Trabbi weighs 1300 lbs. Of course I had 4 adults and 1 child and luggage to add to the mix.
Dad used to do allot of towing with a camper with his 76 Chevy pickup back in the day. It is a trailering special 454 big block. It was a 1/2 ton but he had 3/4 ton springs installed it in after we bought a slide-in camper.
I seem to recall him having one of these weigh distribution hitches. I know the camper was at least 20 foot long. Holiday Rambler.
I'd love to restore this pickup. It's currently just sitting out in the field....
Keep in mind that springs are for carrying the weight and shocks are to dampen the rebound from the springs. And if you lift the weight off the springs with the shocks. Then the shocks will be carrying the weight.
if you were going to tow the car a lot. i would invest in a good used, or new lite weight car trailer. those U Haul's are heavy with serge breaks. then you can use a weight distribution hitch, and E breaks..
more info on the car please.. :thumbs:
It's a 1981 Trabant 601 "S". It was made in East Germany from 1957 to 1991. Mine is the 1964 to 1991 body style. It was discontinued about a year after German reunification.
It has a 2 cylinder, 2 stroke, air cooled engine. It makes 26 BHP. Top speed is around 60 mph. Gas mileage varies. I get 35 mpg where others you live on "flat lands" say they get up to 50 mpg. I just have to push mine harder to make it up hills.
I wanted one when I saw them on TV back in 1989 when communision in Eastern Europe was crumbling. And wanted one every since. I had to wait about 20+ years to import one because most states like Tennessee won't allow you to register anything newer than 30 years if it was never sold here.
Here are some photos. There is also a sub directory of photos I took at the Parade of Trabants in DC this past weekend.
http://s222.photobucket.com/user/turbofiat/library/Trabant?sort=6&page=1
    250.3k
    Griffin Donovan
    Griffin Donovan
  • Who's Online   4 Members, 1 Anonymous, 768 Guests (See full list)
    • Hasn't come up in the 3 gm forums I follow. And only gm knows the frequency of failure of that part. LMG, you want a recall so it's replaced for free...
    • You need a better code reader/scanner.  You are missing codes.  Did the dealer give you a copy of the SAVI scan from that visit?     If the fluid hasn't been changed, change it.  Shudder will likely go away.
    • TLDR to my other post...   Hard. Pass.  Too many what ifs.     Are you set on a 3.0 Duramax?  Have you considered anything not GM just in case?  If you don't have to have a pickup, lots of other options for $27,000 out there.
    • I see some red flags.   - No mention in the Carfax if the oil pump belt was changed.  LM2s had a 150,000mi service interval, and its got 164,245mi on it.  So right out the gate it needs about $3000-3500 for that to be done before driving it another 150,000mi.  Belt is at the rear of the engine.     - If something happens to the transmission valve body, the special coverage is expired by mileage.  That will likely be an out of pocket expense, with zero or near zero GM participation if something happened even though its in by time.   - 2020 LM2s seem to need timing chains after 80,000mi at some point.  They fixed this end of 2020/starting 2021 model year engines.  They will usually set a P0016 I think?  There is another $8000-10,000 if it needs a chain.  The main chain is at the back, secondary at the front so the pump belt would be done at the same time if it needed chains.     - Long oil change intervals.  7,000-8,000mi on average, probably close to 0% or perhaps to or beyond 0% on the OLM.  Lots of them not at the dealer which makes me wonder how much of the oil ran through that truck was the proper Dexos D rated 0w20 oil and not just gas engine 0w20, which is not the same at all.     - Long fuel filter changes, again likely taking the fuel filter life to 0% or more.  First one went 28,603, second was done 43,094 miles later at 71,697, from there another 46,452mi to 118,149mi, and then the most recent one 37,026mi later at 155,175mi.  So counting its original fuel filter, its had only 4 fuel filters on it.  No bueno IMO.         Good news?    - It has had only two warranty trips to the dealer.  The first free service (end of December 2020 on the Carfax), and the transmission reprogram recall (end of August 2025 on the Carfax).     - Truck did a LOT of moving, so that might explain the lack of emissions related repairs like bad NOX sensors, bad exhaust temp sensors, bad glow plugs, etc.         The "emissions system checked" could just be how something was flagged for Carfax.  GM dealers have to do SAVI reports for warranty repair orders so they scan the truck.  So its possible that is there for that?
    • Thank you, @Z45!   NOTE - No all repair shop/Dealers reports to Carfax   That is my main concern.  The CARFAX looks way too clean for a 6 year old anything with 164,245 miles.  Even something known for reliability (like many Toyotas) typically has a lot more replaced, like a Nav screen, interior trim, shock/strut, or brake pads.  And surely the last set of tires (installed at ~58k miles) would be bald unless those were all highway miles.   I'm tempted to pay a local dealer to look up the VIN, but am not sure if that will be worthwhile.  Last time I did this, it was 100% useless, and I felt scammed - they noted the bumper was replaced years ago and that's it.  A 5-year old could spot the accident damage, even though nothing was on the CARFAX.   After giving the dealer a call, the truck may have a hard shift, but they have to verify with their mechanic if that's even a concern.  And I've test driven about a dozen of these now, many near Chicago, and half the trucks shift hard/odd at all throttle positions.  The ones with aftermarket lifts/larger tires shift terrible, and 3 stock trucks shifted so violently I thought the transmission valve body was going out.   At this point I'm conflicted, as I need a vehicle, and am coming up short locally.  Northern trucks in this price range tend to have either multiple owners, a lot of mods (lifts/oversized tires without re-gearing), and are generally in rougher shape.   If this truck showed up in your neighborhood for $27k and you had to purchase it sight-unseen, with the possibility of needing a 10L80 rebuild, torque converter, or rear end - would you do it?  I'm convinced most of the 10L80 trucks I test drove are broken, they can't all shift so bad, with massive flares/slipping/lurching and mis-matched downshifts like a teen driver learning stick.
