Alarming Question
I have a shell on the back of my 14 sierra, and I carry a lot of tools and parts back there and want to install an alarm on the rear window that opens. Ill use a magnetic switch. Does anyone know if its possible to tie into the original alarm, and where?
It should be possible. Maybe check on the front hood switch, I think that is hooked up to the alarm. Not positive but I think it was a purple wire on my 2013 Sierra but i would double check that. Maybe someone else will chime in.
I don't know how to do what you're asking, but I have heard of someone who had a Viper alarm installed with remote control and had the installer alarm the rear window like you are asking for. The Viper also sends a text when the alarm goes off. May be a possibility of you...
Yes it can be done. Here is the approach I used.
http://www.gm-trucks.com/forums/topic/177069-help-with-alarm-trigger-mod/?p=1693523
Videos
That's sweet. So I'm curious, I haven't made my alarm go off. I thought by someone trying to open the doors it would go off and it doesn't? Unless you do this mod?
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
DROPKICK Edition
Your truck needs to have option UTJ-Theft Protection System.
If it does then it should work.
DROPKICK Edition
It should go off if you have the correct RPO as stated AND wait for it to set completely. I can easily test mine by pressing the remote lock twice, then wait 30 seconds and use the key to unlock the door. As soon as I open it, the horn sounds.
I checked this posting out to see what the "alarming question" was.... Come to find out it was actually a question about an alarm......Sorry, I got nothing for you
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
