So is there THE best level/lift kit out there?
Been reading around the forums, and obviously there is a ton of "opinions" and "facts"...
But from more of an engineering point of view, is there really a way to achieve the leveling (and minimum lifting if needed) to achieve a setup that would not lack in a single aspect of premature wear and tear on the otherwise OEM parts leftover on the truck...?
If there is a simple answer and a recommendation of such product, I would appreciate it.
TIA
Like you said it's gonna be all opinion based but, the majority would say anything <2" will be fine. I personally went with Motofab because I liked the idea of them being made of aluminum and not a composite material. But it's all preference. Both RC and Motofab offer a lifetime warranty on their products.
I have read a lot of people using Rough Country, and I agree I will probably go with the 2" level kit.
Subscribing, Id like to buy a kit over the holidays...
very subjective! the shop that installed mine will only do Ready Lift, they swear by them. pretty sure if you get ten response you'll get 7-8 different answers. best thing may be to go on Autoanything or a site like that and read the reviews.
BTW, unless you go body lift (or actual suspension lift with new control arms and differential drop) all will add more wear on the front end. Even the venerated bilstein 5100's change the geometry and increase the CV angles, though they sound to better protect the ball joints when at full extension, they still increase their normal drive angle. For just a level I would say this is the best option but not by some huge margin.
Just keep it reasonable, I am going to go 1.5 front (debating if i want to go bilstein or top spacer) and 1 rear. Most say 2 or under is fairly safe and it depends on what you do with your truck. Just street driving? Should last a while. Hitting regular fire roads and work sites or actual off roading they won't last nearly as long.
As said before, just search. It is a very common question (as is what tire size can I fit or which AT is best) and you will always get multiple answers with people who swear this or that is worst with experience from their best friends wifes once removed uncle who had it happen or it is the best just because they bought it (BFG tires anyone?).
Tyler
I heard the same thing from my dealer and as such had them install the RL 2.25" kit and do the alignment.
Tyler
I agree with your comments. I went 1.5" for the same reasons. I will swap out control arms, when they become available. Cognito is working on a set for the 2015 SD's that look promising.
Tyler
Exactly why I stated in the OP, looking for an "engineering" perspective. As in parts which would need to be replaced in order to not prematurely wear the parts that will remain OEM.
I am coming from a Subaru platform. Once you instal swaybars and end links, that is it regarding that component, the X-axis. There is no more movement side to side, and also there is nothing else that can go wrong (prematurely wear other OEM components).
If you per say put swaybars on and leave stock end links, then the OEM end link will be eaten away by the stiffer sway...
Further on, putting aftermarket springs on the OEM shocks, etc etc etc...See where I am going with this?
Is going with a lift kit which replaces both UCA and LCA as well as the ball joints the answer?
Well this is an odd question, If you are talking just a strut spacer to level your truck than it will all be a matter of opinion based off of what every ones used. But me personally if I wanted the "BEST" lift/level I would go with something along the lines of the BAJA KIT long travel suspension system LOL but the difference between the two is about 5k..
Haha, funny thing you mention BajaKits. Just went over there yesterday and checked out the shop. Damn. Thats all I have to say. Spoke with JT. Super knowledgable guy.
No products yet for the 2016s fyi (to whomever it concerns).
But you are right, out of their 3 setups, the long travel for the Silverado is just pure seXXX. But the base Chase Kit is all around amazing as well. All around it sits at around $4k...
I checked their website, it is expensive $$$!
their mid travel kit and chase kit looks good but needs more pictures and notes.
Tyler
While I'm not a suspension expert by any means, I can say that I researched this EXTENSIVELY having had issues w/ level kit before on a tacoma chewing up end links and ball joints, and from what I understand you are wrong - the bilstein 5100 shocks DO NOT alter or effect suspension geometry.
They effectively raise the height of the spring perch, the angle of the control arm & thus ball joints in relation to the shock is not changed, the length of travel is not changed and the spring is not compressed.
I don't know how else to say it - just read: http://www.bilsteinus.com/fileadmin/user_upload/user_upload_us/pdfs/Bil_LevShks_WebArticle.pdf
You can put chintzy pieces of plastic blocks of aluminum between your shock mount, compress your spring, chew up your ball joints, and have a harsh ride, or you can go the route of bilstein 5100's and level it "the right way" and get a better ride and better on/off road performance compared to stock at the same time. I do agree if you want a "real lift" you're way better off doing a complimentary body/suspension lift w/ nice fox shocks or something - but I completely disagree that the bilsteins will compromise suspension geometry.
Also - there's a reason why a legit factory offroad truck like the powerwagon comes w/ these shocks as OEM...
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 1,554 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
