1984 K20 dual tank wiring
I have a 1984 K20, 350 with Dual tanks. My left, right selector switch is bad. Does anybody know how the wiring would go if I was to remove the switch, eliminate the left tank and just use the right tank.
If you are ditching the tank, I would think you should just replumb the fuel line and get rid of the whole selector system.
I couldn't find the wire diag. I did look thought. Can't be that complicated, take the two leads from the working tank side and connect them together to bypass the switch, at the switch. All the switch does is complete the circuit.
