Grill Overlays? Anyone got them?
3 hours ago, chevydeth said:
look's good - wish i could find one for a chevy.
  • Replies 35
On 4/19/2018 at 6:37 AM, Cheverado said:
Got Mine yesterday. Absolutely recommend using double sided tape. Gives it a tight fit.
Two weeks old and to realize it ain’t to my liking. $75 ships this one anywhere on the lower 48 states. IM me
Warning to anyone thinking of replacing their grill overlay: if you have the factory black plastic overlay it DOES NOT come out of the grill. Im not sure about the ones that have the Z71 badge but mine that is just black plastic did not come out when I went to replace it. The plastic is all connected throughout the entire grill.
So this just mounted over your black grill bars ???
  • 1 year later...
