running board configuration
Have you looked at the running board websites? I believe it will show different boards for the different models. However, you might be able to order brackets to adapt the board to the model truck. You would need to check with the manufacture to see on that.
If you have the new molded mudflaps they will not clear. We've tried. They bolt up without flaps, but the steps are further forward than the new ones. The step pads don't line up either.
