Suspension Upgrade
tthomas
  • Replies 49
If it comes in under 4k I would be suprised honestly. You are looking at around 2k just for the shocks. I am buying it reguardless...Just have to start sneaking a little money from the wife every week till they get released, Ha! Hopefully they come out before I need new ball joints. Maybe they will sell it with a diff drop kit also. Anything above 2" in the front is a little sketchy if you plan on using 4x4 on a regular basis
Yeah, I agree. if it's going to give 3" of lift, they should drop the differential. If not, the CV angles would be terrible. It would be nice if they offered a more economical option with a different brand of shocks, with Fox being available for an upgrade. But, then the ride probably would't be as good. Your truck is only raised 2" in the front, right? Do you think your ball joints are already starting to wear out?
Thats right, only 2" on mine. The ball joints are still good and tight I just know it is coming, ha!
FTS21108 is the ball joint kit
FT21130 is the uniball kit
You can get these kits in any combination.... different shocks,ball, ball joint....etc
So because I don't know much...what are the differences between uniball and ball joint kit. Advantages etc??
i wish I could honestly answer that question..... The worst part about it is, im not even sure which kit I have. Terrible I know
Uniball will offer a wider range of movement. They are mainly used in racing aplications. If you live somewhere with alot of salt or sand they will wear quicker because they are more exposed. They require more maintenance also. Ball Joints is what you want unless you plan on doing a mid or long travel suspension. I had a set of Camburg's on my 13 1500, I didn't have any issues but I live in North louisiana and stayed on top of the maintenance
Thanks! I live in western ny. So lots of salt and sand in the winter.
It MIGHT have diff spacers but the angles are still going to suck, its suspension lift money and yet not a suspension lift..
Yeah I agree. I'm curious to see the full details when they're released.
I am a member for some time but this is my first post. I have a new 2016 GMC Sierra 2500hd on order and thinking of leveling it. I was looking at the suspension cam lift and would like to know if anyone has a opinion or experience with this kit? The link below is the kit in question along with a installation video. Thanks for any help that may help.
www.suspensionmaxx.com/store/product/SMX-MC5
I was looking at this system as it might have closer to factory ride. They use spacers to lower front axle. Any one have any pro's or con's on this kit. Try you tube link below for video of kit.
Those aftermarket torsion keys do absolutely nothing. Twisting the bars is twisting bars, doesn't matter how you do it. IF IF IF you can not achieve the lift desired by turning the torsion bar keys up using the stock bolts THEN you can begin looking into keys but you should know if you are cranking up enough to need keys you will start needing other parts as well.
Lots of sloppy keys out there, NorcalNick did a nice YouTube video showing how sloppy the different keys are.
So after leveling w/keys the uca's hit the stops. will Cognito uca's alone, for example, be all that is needed to clear the stops?
    DaleB
    DaleB
  • Who's Online   7 Members, 0 Anonymous, 1,301 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
