1991 silverado Fuel pump
Fuel pump is starting to go out on my truck and I know they can get pretty pricey. Any suggestions on fuel pumps that are cheap but good quality? You know ones that won't go out again in a year or so. Thanks!
Sent from my HTC Desire 626s using Tapatalk
Fuel pump is in the gas tank, $50.00 O'reilly's, I put in GM pumps since you have to drop the fuel tank about a $100.00 I think.
There was a tech service bulletin on these fuel pumps which I had not seen.
The reason they fail early (according to GM) is the plug connector in the wiring harness doesn't make a good connection, and allows a slight voltage drop to occur, and running the pump on lower than spec'd voltage is what causes it to run overtime, and fail early.
I put 2 pumps in my '96 K3500 before knowing this. Two pumps within less than 40,000 miles, mind you. :/ But of course at 9 to 10 mpg the pump is doing more than double the work that most fuel pumps do.
One of the pumps that I had fail was a Bosch, which was supposed to be better than OEM. I don't know how long the Delphi lasted that was in there when I got the truck, since the truck was used when I bought it.
I then had what was supposed to be the OEM style pump, and it lasted about 20k miles and quit.
A friend who runs a garage told me that most fuel pumps really don't fail, the connector that attaches the pump motor to the sending unit and related hardware actually gets corroded and fails to make good connection. He said you can take most "bad" pumps out of the tank, and wire-around that connector, and the pump will run fine.
Of course you want to go with a new pump while you have everything opened up. Next time I have to put a pump in (not anytime soon I'm hoping), I'm going to eliminate that plug by hard-wiring it, and sealing the connection with gasoline proof sealer.
I did replace the factory wiring harness plug which GM recommends. It's a 3 wire plug, with about 6 inches of wire attached to it. It's only around... FIFTY DOLLARS (what a rip off)...
I guess you could hard wire around that plug too, sealing the connections up well, perhaps soldering them first.
Good luck with your repair. There are some steps you can take to hopefully make this the last fuel pump you'll need to install.
Dan
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
