2016 owners - quick question
Do you notice if your rear defrost turns on automatically in the morning? I have noticed this after the truck sits overnight. Its been warm here, so I don't think it has to do temp. Also, I'm referring to a normal key start. Please advise .... Is this by design?
Well. There a rear defrost auto start option in the vehicle settings, but this is only suppose to turn on when it's cold, 32 degrees or below cold.
Some folks have mention that the auto start will start the defrost even if there is frost on the window. May not be fressing, but it just senses frost.
Is the option checked in your vehicle settings?
Yes...but the temp hasn't been below 65 here since I got the truck
Sent from my XT1254 using Tapatalk
It seems if the option is turned on...the defrost will come on regardless of temp...if the truck sits all night
I thought the 'auto' setting for rear window defog only referred to when started by remote, but it makes sense for it to work after keystart on cold days.
Now you have my curiosity up.
This is where I stopped reading :idiot: Joking.
Curious if there is a sensor for condensation or moisture instead of just a blanket temperature to turn the system on?
I think just temp. I used my remote start when it was 29 out and my rear defrost was on when I got in. And the windows were clear.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,137 Guests (See full list)
