New member
71wideside
Hello, I am new here, I drive a two tone trim all white with blue interior 1971 GMC single cab wideside, original vinyl bench seat with a small block 400 equipped with an extra large air filter and quad barrel Holley carburetor and a 700R4 hydraulically operated transmission. I inherited this truck from my father and I am sad to say that currently the seals on the transmission need replaced and the gears respaced, along side a new battery and a set of tires. She is a little worse for wear but that small block still roars with power and good old fashioned American muscle.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
