Changing Interior Wood Grain
I would like to change the type of wood grain on my 2015 Sierra Denali. It has the black interior with a black wood grain. Cant even tell its wood its so dark. Ive looked on line for the kits but none of them have the replacement peices only add on like for the dash and vents. Only want to replace whats there. Thanks for any help.
I think I would like the dark wood on my truck versus the mahogany looking wood trim. Maybe we could do a trade if its easily removable?
trade with someone . paint them or vinly wrap them ? my last truck I painted them body color.
