ok so first off I want to say im new here and I've tried over and over to search and its not working out. so, sorry if there is already a thread with this
i just bought a 2015 Chevy Silverado 1500 2wd a few months ago. I'm getting a 2.5 level installed and would love to run 285/75r17. does anyone run this setup or tried to?
if so, can can you also post a picture.
thanks!
Edited by ktm237
You'll have a slight rub in reverse at full lock... Nothing to worry about.
8C8A8C61-2DDE-486A-9096-9A33F66334AF_zps
are you running the fox coils? or what level kit? yours is exactly the look I want with different rims tires though. glad to know they fit. you didn't have to trim anything did you?
I have the Readylift 2.25" with Method NV 17x8.5 0 offset and 285/70/17 Duratracs. Only a very very slight graze of the felt wheel liner in reverse at full lock. With 2.5" you will be fine.
What's od on 285/75/17?
I'm on a 2" RC Level with 285/70/17 Cooper ATP and Method NV 17x8.5 0 offset. No issues at all.
Sent from Tapatalk App - Samsung S6
Sorry, what do you mean by what's "od" on 285/75r17
285/70R17 is a common (nearly) 33" tire for 17" wheels. A 285/75R17 is an uncommon size. Hence he's asking what the overall diameter is in inches. Are you sure you haven't mistakened a 285/70r17 with a 285/75r17?
Exactly what I was asking.
Oh gotcha! No I have not mistaken the 285/70r17 for 285/75r17. The OD IS 33.8 on the 285/75r17, so about an extra inch.
I think you're going to need a bit more than then 2.5" level to run 33.8 (~34") tire. I could be wrong though.
The very first picture posted on this thread is the silver Silverado. He's running 285/75r17. We will find out next Tuesday if it works or doesn't work. I'm ordering the rims and tires today.
Cool, good luck.
What rims and offset and width, that will play into it as well.
That first pic looks a little nose high, is the rear on stock blocks or raised too? Might just be the angle.
Cool, good luck.
I'm going to be running 2.5 level with 285/75r17 toyo at2 or cooper at3 (I want the toyo but the coopers are cheaper and way abkut 10 pounds less per tires) with fuel boost 17x9 4.75 back spacing with 0 offset
    • They are talking about adding more tax to our fuel across Canada by the labour day time frame, its the carbon idiot tax increase on top of the pile of fuel taxes we already pay thanks to the WEF dictatorship running the country. 10 cents per liter on gas and 4 cents a liter on diesel I believe is what was said. That is a huge amount of a tax increase as its another 38 cents equivalent to a US gallon of gas. The reason our fuel is higher than the states already is because of of the high taxes they have imposed on fuel.
    • This is just a thought as I can't claim this is the correct thing to do but will suggest it and you can decide if its something you would try. First round up some electrical contact cleaner spray as they at least claim its not supposed to damage the components ( brake cleaner depending on the type is a real destroyer of plastic etc ) and to use that to assist to clean out any grime from the pins as well as the mechanism by spraying and working the lever etc. Then my next thought is to use silicone spray lube and not on the pins but on the seal and the pivot assembly. It may not be possible to spray it on certain area's and have to use a q tip as Davestar mentioned to keep it from getting on the pins. Dielectric grease can be fine on some things but its easy to get too much on if not careful and then gunk things up and a possible risk of getting it on the pins or sockets. The silicone spray is able to get into a mechanical component to help lube and on surfaces its just a fine film to reduce friction such as that seal. Also it can be doused off with a good flush of the electrical contact cleaner the next time for a repeat of a "clean and then lightly lube" step process to wash off any dirt that had stuck to the exterior etc of the plug.   Free advice, yes. Good advice ... now there's the question mark !
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
