Pandora Error Message
VA_Rob
From time to time, I get the pandora error message and Pandora will not play from my android phone. Usually, I can fix it by pressing the home button and then going to regular radio then back to pandora and it will acquire the signal . anyone else have this issue? I would say 70% of the time it works fine. I've had the truck about a month.
2015 Chevrolet 2500hd ltz
I see this on my iPhone as well. Usually it is because I did not enter the passcode on my phone or I forgot to plug in the USB.
Mine does this 90% of the time and with the Bluetooth audio with my Galaxy S6 edge. I usually have to manually start my music app on the phone then it will play and I can control it from the truck with Bluetooth audio. I pretty much expect a Pandora error, check connected device error about every time I try it and I usually have to close out the app and go to the radio and back to Pandora then it will start. I think my issue is with my junk phone though.
  • 10 months later...
I’ve been monkeying with this for months now and I think I figured out the fix. Well not so much a fix, more a user error on our part. The trick is to launch both the app from tour phone AND from the Home screen in your truck once the phone is plugged in. When I got the truck all I had to do was plug the phone in and hit the app on the home screen, so somewhere along the way that changed. Don’t know if it was Pandora or GMC, but it changed. And the instructions on Pandora’s site [https://help.pandora.com/customer/portal/articles/190368-pandora-and-gmc] have a step to do both.
So there you go…hope this helps.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
