Chevy knock
With it running start pulling plug wires one a a time, if it changes that cylinder has a problem. Lifter, rod, cam, piston pin? Timing chain is on front of motor.
could be a hv leak, sounds like it is at 1/2 crank speed...maybe lifter
Not sure. I havent had someone rev it yet but i will check. I pulled the oil pan yesterday and all the rod bearings were good. Oil pump pickup tube oring had a little slit in it. Stil lwaiting for rtv to dry then i will fill it up with oil and see if its still there or not
Just for the giggles of it all, what is oil level and condition? Maybe just a matter of needing an oil change or it's low? Probably not either of those but cheap check to verify.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
