aftermarket stereo system help
6.2Frank
The LC8i could be the solution due to this feature as it would allow you to use front and back inputs and regulate the front pair level.
Level Matching Controls
Your LC8
i
has level controls for each pair of channels. These controls
allow you to adjust the signal level from your factory-installed amplifier
or source unit to match up with your after-market amplifier or processor.
The Auxiliary input also has a level-matching control to balance it with
the main inputs.
http://www.audiocontrol.com/downloads/car/current/lc8i/lc8i-user-manual.pdf
Now the only thing factory that still is in the truck is the Headunit, the tweeters and all the speakers have been swapped out for Alpine Type S speakers. Would this have any effect on the LC8i?
I think that is exactly the point of the LC8i.
It serves to take the output from your factory head unit (in this case the Bose amp outputs) and then convert it so it can be used effectively by the aftermarket amps to power the aftermarket speakers.
Ok so that would help with the chimes, Bluetooth audio, hands free audio, and onstar issues? I mean the place told they can restore all the sounds but it'd be extremely loud due to the amp.
Using the Audiocontrol LC8i most likely will not change the volume of the chimes, especially if your getting the output from the Bose amp. The LC8i will sum channels in order to get a full range signal, and will sum the channel including the chime signal. This will effectively put chimes in all speakers. in order to get a full range signal, the front dash speakers, front door speakers and the sub signal are required. The bose amplifier has already separated the signals from full range to each speaker. Mosconi solved this issue with allowing % of signals to be used for select outputs.....reason being I am using a Mosconi, and will still be using one after I install the Alpine X110-SRA
Personally I have not installed using an lc8i but in theory and looking at the manual it should allow you to control the level of input from the left front speaker to the amp and combine it with the other inputs to the aftermarket amp.
You can suggest it to the shop and see what they say.
It is true that if they just use the straight front speaker source to your amp the sounds will get loud.
I do think they should have mentioned this might happen before doing the install and let you decide rather than just take the sounds out completely.
Adding the speaker off the factory outputs may do the trick as well
The Mosconi unit feature sounds like a better solution than the LC8i that only allows level by pair vs individual input.
I believe the Bose Amp actually has full range signal off the front doors, so there is really no need to sum dash+door+sub to get a full range out. AFAIK.
Going off this post:
http://www.diymobileaudio.com/forum/build-logs-project-install-gallery/159994-2014-chevy-silverado-musicar-northwest.html
The signals coming from the doors do not reach 20K....... they are purely midrange.....you will need the dash speaker signal in order to get the full range....the pictures you linked to I posted a while back, the dash signal was measured at 15khz, while the door speakers were measured at 50hz.....
Racinghart user posted the following diagram of the Bose wiring output (UQG.)
Is it incorrect?
According to this diagram the front signal is full range, then gets split off to the dash, assume with a capacitor to cutoff the lows.
If what you are saying is true , then the Bose would have to be sending out an entirely separate set of outputs to the dash.
Is it incorrect?
I see your point in referencing the schematic.
After working with my system, I can assure you that something doesn't seem correct with that schematic. The color codes do not match mine. In example, it shows that both the front dash and the front doors are using the same color coded wire. This is not correct. The outputs for the amp are as shown in my reference attached.
If you want to go with that schematic, then this leaves you with two options, no chimes, or with chimes. See my point?
Alpine head units with iDatalink Maestro utilize a separate small speaker for chimes, but are also not compatible with Bose from my understanding. The chimes originate before the Bose amplifier, and for some reason are not amplified by the Bose amplifier.
2014 GMC Sierra Bose Amplifier Line Out:
(NOTE: This should be correct as far as POS/NEG, I only had my first draft from on my phone to post this)
1st HARNESS SUB (POS+) Blue/gray
(NEG-) Grey/black
FRONT RIGHT DOOR (POS+) Yellow
(NEG-) Yellow/black
FRONT LEFT DOOR (POS+) Blue/black
(NEG-) Brown/blue
2nd HARNESS REAR RIGHT DOOR (POS+) White
(NEG-) Blue/black
REAR LEFT DOOR (POS+) Green
(NEG-) Green/black
FRONT RIGHT DASH (POS+) Brown/green
(NEG-) Brown/purple
FRONT LEFT DASH (POS+) Yellow/blue
(NEG-) Yellow/gray
Well here's an update, I took the truck in and basically what they was install the speaker in the dash and that is being powered by the bose amp, but the volume is low for bluetooth audio and the chimes. He told me its all because of the magnet size and the bose magnet were pretty small to begin with and didn't require much power and the speaker they used has a bigger magnet and that's all they can find so we figured out that if we had another speaker that we threw under the passenger side of the dash the audio quality would be better when it came to the chimes and bluetooth/onstar audio would be better. And that left us the those whole lack of power to power the 2 speakers since the Bose amp is short of that, so I threw out the idea if we get another amp to power the bose amp to power the speaker if that would work and he said that it will and shouldn't be an issue as long as the amp is a 200watt amp. So we'll see how it'll work out, i'm not paying for this the place stereo place is paying for the equipment since they didn't warn me about anything so lets see.
  • 1 month later...
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
