Interior led
Have a 2013 and want to replace the interior bulbs with led. What is everyone using or recommend?
I got mine from www.iJDMTOY.com. Also got the tag light bulbs. No problems and several color options available (I got white).
For those that get from superbrightleds, do you have a link to the bulb you use? Would like to know which are the good ones and not so good.
I ordered some from superbrightleds. It seems the ends where metal is different. There's part on the LED that's bigger. How did you all account for that? It looks like only 1 end of the big goes in my connection and other end uses small. And that makes the bulb connection kind of loose.
those of you that have them... any issues.. i installed some on my truck and when i flip down the visor and open lid.. it shuts off my dash lights
I ened up getting the canbus ones after the non and those dont work either. the heatsink is longer than the connectors my bulb snaps in. sending these back as well. wish I knew of a good quality place to get some.
Maybe you didn't understand the responses people left here for you???
There are links posted telling you where others have purchased their LED's, what more can you possibly want?
Seems like you ordered the wrong size bulbs, that's your mistake. Order the proper size bulbs and you will not have any issues.
No I perfectly understood the responses others left here. That's why I ordered from one of them.
Not a damn thing. Where did I give off I wanted anything. I was simply informing others of my experience.
In fact I ordered the correct bulbs. Superbrightleds actually said I'm not the only one that's had this. They've seen it before. They also confirmed I ordered the correct bulbs.
I'm not a ****ing idiot. Why don't you go be a smart ass on someone else's thread instead of mine. Thanks for wasting both of our time with your useless negative smart ass post.
The pic below also shows that the contacts on the led bulb are further apart than the factory bulb. You can also see the heat sink on the other side of the board is longer than the glass which was too long to fit in the prongs where the bulb goes.
Ok what is wrong? I have the Superbright LEDs in my truck. Had them for about 5 years. Haven't a single problem.
When installing new bulb take the connectors where you would put your new led in the dome squeeze them both in to make a tighter fit. Then put your bulb in.
If they are in tight and are not coming on try flipping them around.
https://www.superbrightleds.com/vehicle/2013-chevrolet-silverado-1500?make=16&model=1504&year=2013
You have 2013 Chevy Silverado
Yes I know what I have. The bulbs are too long for the connectors. So flipping around won't help. Like I said before, the heatsink is longer than my connectors so it won't fit right.
Also, flipping around would put the heatsink facing down and the LED up which is pointless.
    mighty K20
    mighty K20
  • Who's Online   4 Members, 0 Anonymous, 566 Guests (See full list)
