Locked out of truck, need help
As it says I'm locked out of my truck. The key fobs do nothing, and putting the key in the door lock does nothing, it will not budge. I'm stumped. I just used the truck 2 days ago no problem. WTF??
I can understand the key fobs doing nothing, But how on earth does the key not open the door lock? Have you used the key in the lock before?
Did you wash it ???? hair dryer, lock deicer . check battery in key fob . I spray mind with WD-40 , 2 or 3 times a year. good luck
WD-40 on the lock. Since you don't use it, I bet it has become stuck. I know that has happened to me before. Now I try to use the key to unlock the door once a month.
The battery was completely dead in the truck. I sprayed the key lock with WD-40 and eventually it broke free and I could get in. Replaced the battery in the truck, and both key fobs, good to go now. Thanks.
Good deal! Now that it has happened, you'll be more likely to try the key every now and then. It has saved me for sure.
Use some good lock lube in there. WD40 works in a pinch but use the lock lube that is designed for locks to keep it maintained.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 706 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
