2015 CC 4x4 Help Pick Wheels!
Ok guys I've got a 2015 victory red cc 4x4. I already have a 2.5 level just need to get it put on. I can't make up my mind on wheels though. I really like chrome but I want whatever will look the best on red. Right now my favs are chrome: gear big block 20x10, xd riot 20x10. Black: gear big block, moto metal 970 black and machined 20x10. I love chrome hostage in 20x12 but I can't fit them and don't want them sticking out that far. Please Help Me Decide! Thanks
Never understood why people like having their wheels stick out a mile past the fenders. Looks dumb in my opinion, and just chews up paint even more...
To each his own. I think it looks amazing! Granted the red one sticks out to much. I want to do a smaller version for sure
It's all in what you like. I was talking about the red one too. It looks okay with some sticking out, but not like the red one.
Some of my inspirations
Take a look at some of the Hostile wheels. I have 20x10's and they are plenty wide enough for my taste
Pick the ones that you like the look of the best :dunno: Not sure why you would ask the internet to pick your wheels you have to see and live with every day... If that was the case add a poll with your choices to vote on.
If it were me I would get some chrome rockstars 22x14 and wrap them in bfg ko2's. Make sure you install a 50 inch roof light bar and lower the rear as well, oh and 10k hid's in stock reflector housings, boom, that would be a sweet truck bro!
Tyler
Agreed. Looks so stupid. Like the truck is inbred or something.
I like the "cencal" look. But not to extreme, I'll probably end up putting on a leveling kit and 20x10s with 33s. Just trying to get some ideas what people like then I'll form my own opinion. I like a nice deep lip we wheel with an aggressive all terrain or mud tire.
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
