Wasn't that bad.
First open your console lid. With it open, now you will have to pull up and back on the top grey plastic piece that goes around the entire console which is also connected to the cluster part that holds all the 12V and power supplies. Once you pull that off you will have access to the back of the plugs. You can pinch 2 prongs that remove the 12V outlets. Remove whichever one you want.
Remove the socket from the plastic housing and your switch will fit right in the plastic housing piece.
Clip back in and you are good to go.
Just tried it and Worked like a charm. Thank you for the info!!! Greatly appreciated.
No problem.
Side note: If the switch is a tad loose, take your switch out and put 1 or 2 rounds of electrical tape around your switch then slide it back in. Will fit like
At least that's how mine was.
Looking to see where everyone is mounting their aux switches for light bars on the 2014+ GMC's. I have the trailer package so the trailer brake is in the way on the left side.
I have a couple cubes and a bar I want to put behind my grill but would like to have an idea of where the switch can go.
Anyone mount a switch in their center console?
How about on your keychain with the door remote?
Single or multi-channel remote control 12v 10A relays are available on EBay for less than $10. Channel A controls the LED spots on the sports bar and Channel B the LED floods behind the grille. Plus you can control the lights from outside the vehicle.
One of many on EBay:
http://www.ebay.com/itm/315MHZ-DC-12v-relay-2CH-wireless-RF-Remote-Control-Switch-Transmitter-Receiver-/121532355607?hash=item1c4be49417:g:WRwAAOSwc0FUpfUv
  • 5 years later...
I got the 6 Gang Switch Panel, OFFROADTOWN Electronic Relay... https://www.amazon.com/dp/B07PZ7C5XJ/ref=cm_sw_r_sms_api_glt_fabc_1N1B9CGVAB8HRJ12M383?_encoding=UTF8&psc=1
I mounted the relay box and made the connections in the engine bay. They light up green when off and yellow when on. Works greats for what I wanted and way cheaper than some of the others I’m seeing out there
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 641 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
