Random Windshield "pop"/ "snap" sound??
Hey guys, anybody experience a random windshield/dash "pop"/ "snap" sound?
I hear it every now and then. Very random although I almost think it tends to occur when the truck flexes as when taking a low speed corner or say driving over a diagonal angled speed bump type scenario. Bugs the shit outta me as I can't figure out what it is. My thoughts are possibly the windshield adhesive or dash but I really don't know. It doesn't leak at all. Seems to come from the passenger dash corner area. Baffled.
Any ideas?
Thanks
Does this occur when you are going fast?
do you have a bug windscreen shield anywhere?
have you contacted the dealership?
has the windshield been replaced?
<My guess, i think its the gasket/seal for the windshield. sometimes it isn't installed correctly or wears out. Contact dealer as long as its the OEM wind screen, they should fix it free of charge.
Happens most driving around town. Slower speeds. Once it happens it's almost like something reseats itself and I won't hear it again for a day or so. When it happens I can't reproduce it either.
No windscreen shield, haven't mentioned it to my dealer, original windshield.
Does it sound like a rock hitting the windshield?
Mine does this almost daily for sure. My 02 Avalanche did the same. I thought i remember reading several members experience the same thing. Probably is normal.
Yes sounds just like a rock hitting the windshield. Sometimes I'm actually looking for the windshield chip! lol
Def sounds like what you stated , wind screen or dash
take to dealer and have them fix it, but that just me.
In the off chance, is it a metal hitting metal sound?
but what i think you should do is (If under warranty) take it to the dealer. That's the safe first step
Must say it doesn't sound like a metal hitting metal thing.
Def like a rock hitting windshield.
I just started hearing the stone off windshield sound and like others was looking for the stone chip. it only does it first thing so if nothings wrong I can live with it.
Mine does it too. But having installed autoglass I know it's not the windshield, moulding or the urethane. My guest is a cowl or trim clip. I will get to mine once the weather warms up as I'm better qualified them our local dealer tech.
Mine too. Sounds like a rock.
May ask at next oil change if they have had complaints and/or a remedy.
Not a daily occurance, though. I think it is from cold weather.
It's exactly what CWilliams said, the trim around the radio. I have had my truck since September 2013, and I have probably heard it at least 500+ times. It will fool you into thinking it is the windshield at first for sure, until one day you are touching the trim around the radio with your fingers at the same time it does it. Then you'll know exactly where it is coming from.
The good news is after 2-1/2 years, it doesn't do it very often anymore. The bad news is you will have a bunch of other rattles to take its place. One is the clip for the trim piece in the lower dash below the steering wheel. That SOB started at about 30,000 miles, and will drive you nuts. At least until you stick something between the two panels to shut it up.
Like was said earlier, the stone hitting the windshield sound is actually the plastic trim around the radio/CD player snapping due to temperature changes.
it is actually your radio making that noise. TO be more specific, it is the housing above the cd player.
Give it a push on the top and bottom, you will hear the same sound.
THere is a LOOOOOONG thread on this here somewhere.
JC
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
