So i purchased a key fob online that has the remote start button. Looked online and says if you have the Code AP8 on the top of the sticker in the passenger glovebox your truck has remote start.
Had the dealer program the remote and the locking doors work fin but the remote start does not. The signal is sent to the truck because the lights flash just like it does when it is supposed to start. I asked the dealer, they told me that i do not have the remote start feature but im reading everywhere online that the code AP8 means your truck has the feature. Any help on this would be much appreciated.
AP8 is NOT the remote start code, AP3 is for remote start, AP8 is the remote start prep package, which means you can add remote start, however just buying a fob and programming it will not turn on the remote start feature, you must purchase the GM remote start accessory package, the package gives you 2 fobs, a decal to place in the glovebox, and most importantly it gives you an unlock code that the dealer needs, with this code the dealer calls GM techline and gives them the code, techline then gives the dealer the proper reprogram code to turn the remote start feature on.
Heres a bulletin on adding the remote start....
#PIT4082J: Information On Adding The GM Accessory Remote Start Kit - (Aug 1, 2012)
Subject: Information On Adding The GM Accessory Remote Start Kit
Models: 2007 - 2013 Cadillac Escalade, ESV, EXT 2007 - 2013 Chevrolet Avalanche, Silverado, Suburban, Tahoe 2007 - 2013 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
This PI was superseded to update recommended field, model and model years. Please discard PIT4082H.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
The following is additional information on adding the GM accessory remote start kit.
Note: This does not apply to the bi-directional (2-way) remote start kit.
Recommendation/Instructions:
Vehicles must have the extended remote start option RPO (AP8) in order to add the GM accessory remote start kit. This kit is only available on automatic transmission models. Every step of the instruction sheet needs to be followed exactly in order for the remote start to operate properly. Here is a brief summary of what needs to be performed.
  1. The BCM needs to be programmed for remote start by contacting the Techline Customer Support Center (TCSC) @ 1-800-828-XXXX and having them add the remote start function to the VIN number so the BCM can be reprogrammed by TIS2WEB. After reprogramming the BCM, the vehicle will need to be shut off for 1 minute and then the SIR restraints ID will need to be setup by using the "Set up SDM primary key in the BCM" under module setup category in the BCM.
    Note: Once the remote start option is added to the VIN at TCSC, the option will always be available even if the BCM is replaced or re-programmed at a later date.
    Important: The Brake Pedal Position (BPP) sensor MUST be re-calibrated anytime the BCM is reprogrammed on 2012 or newer vehicles.
  2. The remote start instructions state that the BPP sensor will need to be re-calibrated. Starting with the 2012 Model year a BPP sensor was added to the trucks and the BPP Re-Calibration MUST BE PERFORMED. However, the 2007-2011 trucks are not equipped with a BPP sensor so the re-calibration cannot be performed and is not necessary.
  3. The Theft Deterrent Module will need to be SPS programmed with the remote start option selected.
    Note: Please select TDM in the controller list and not VTD relearn when re-programming the TDM.
  4. Clear all codes in all the modules on the vehicle.
  5. Program the new remotes (supplied in the kit) to the Remote Control Door Lock Receiver.
  6. Installation complete.
Troubleshooting: Remote Start Inoperative:
  1. If the vehicle is equipped with RPO UK3 Steering Wheel Controls with the Drivers Information Center (DIC), make sure remote start option is turned on in the DIC.
  2. Make sure the Remote Control Door Lock Receiver is calibrated for the remote start option. Most vehicles with the RPO AP8 should already be programmed for remote start.
  3. Make sure the vehicle has adequate fuel (above a 1/4 of a tank).
  4. Make sure there are NO DTCs.
  5. Check for any of the disable conditions listed in SI Document ID# 1689813.
  6. If B1370 code is set and the RVS is inop then verify that the TDM has been programmed for the RVS selection.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Edited by MS3DALE
MS3DALE is absolutely correct. My brother just went through with this on his '11 2500. Absolutely no way around buying the GM package deal if you want a factory remote start. Oh well, at least he has 3 fobs with remote start, and his original one without.
  • 3 years later...
I've checked everywhere trying to get the "GM Remote Start Accessory Package"  I have called several dealerships & am told that that part # is discontinued.  No one will help.  Can I buy the OEM Key FOBS elsewhere & have a dealership work on the unlock code part?
Best advise to proceed?
Thanks,
Steve
Condition/Concern:
DO you know where I can get the GM Accessory Remote Start Kit?  Every deal I've called will only tell me that the part has been discontinued & I end up in a vicious circle between service and Parts.
Steve
Steve
Steve...Can you post me the last 8 digits of your VIN? They have discontinued some of the kits, but some are still available that may work for you, but I need your VIN to verify.
Sure Thanks!  The last 8 :  BZ296670
The Part Number that I have been trying to get is 17801236
Steve
Steve
Steve.….
17801236 is discontinued, however I called our local GM-ADI (which is GM's accessory distributor installer in our area) its been replaced by part# 22970855
Ok, I looked up the part on several parts websites & most of them has said that this part doesn't work for my truck.  Do know if this part comes with the Authorization code for GM? I'm hesitant to buy it until I can get some verification.  Should I take this part number to the dealer & have them verify that its correct?
I just dont want to shell out a bunch of $$ if it doesn't work.
Steve
Steve
Part# 22970855 replaced part# 17801236, Your local dealer can call their ADI as well to verify if you want.
Its discontinued.
GM shows no superseding part #s for 17801236 in EPIC either, nor does GM show 22970855 replacing it.
Their engineering notes show no superseding number either:
Quote
PART NUMBER 17801236. TRANSMITTER PACKAGE. IS DISCONTINUED. FOR REPLACEMENT TRANSMITTER. USE PART NUMBER 22936098
10 minutes ago, newdude said:
Its discontinued.
22970855 is the number we've used here at the dealership, it's worked fine.
  • 8 months later...
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
