Aftermarket stereo options
I just bought a new 2015 Silverado, it has the 4in. Screen and head unit and a backup camera. I'm wanting to upgrade to a aftermarket head unit that will allow for subs and better sound control.I know the mylink will no longer work but does anyone know of an all in one unit that will be compatible with the Bluetooth for phone calls and audio tracks and also support the back up camera?
You can buy a kit that let you still use bluetooth and also setting for vehicule (as light )
But to installing aftermarket radio you will need to broke the dash behind the radio because it doesn't have enough room to sit a double din radio. ....I would suggest you call MVI before doing anything. ....they can upgrade your io4 to io5 or io6 and also include great function like text..video in motion. Android auto and apple cat play.....they can also have solution for sound control......at least take info from them before
My friend Kyle and I are currently working on the best way to add a system to the bose unit without the crazy chimes and time delay issues when collecting a true full range signal. Should be finished by the end of May. He currently uses the 4inch stock display and you should see his system, let alone hear it. My system is bose 8-inch display.
Please Vote for my Car Audio Build on Facebook.
Phoenix Gold Car Audio Build of the Month (#PhoenixGold #PhoenixGoldBuild)
To vote you have to click on the picture/link below and then select the VOTE button. It may ask you to log in, and if it does, you have to log in to your Facebook account before voting.
Voting Ends on April 30th so please help me out and VOTE before then. This is the very first build competition they have done and its just fitting a GM truck wins!
http://woobox.com/tw8dew/gallery/fl5HEuZNnk0
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 840 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
