1500 under powered
A gasoline engine is designed to rev, if you need legitimate towing capacity without breaking a sweat you might need a 3/4 ton diesel? Is it worth it if you don't tow regularly? Pro's and con's...
I was in that spot a few months ago and the diesel just doesn't make sense if you aren't hauling everyday and using it like it should be. Maintenance is higher, initial cost is higher, bigger to maneuver in parking lots, stiffer ride down the highway, but BIG trucks are pretty sweet. The diesels seem to hold their value longer though, that is a benefit for sure!
If the wallet can handle it get diesel! If not maybe try to find a used NHT package 1500. I love my dad's 2010 6.2L NHT truck for hauling. I ended up getting a 2014 6.2L DI with 3.42s, not quite the same as the NHT package but definitely no slouch when pulling a the racecar with an open trailer loaded with tools, gear and 4 adults.
I think you're just trying to convince yourself that you need another truck. Your feeling are going to be hurt if you think a 6.0 is going to pull the tongue off the trailer. For what it's worth. I have a new duramax that gets 11 mpg pulling a lawn mower on a 7x12 single axle trailer.
it wont be any different with a 06 6.0. the truck will be a little lower geared but not much. its going to rev its going to shift. trans should get close to 200. ibc was not a option until the 07.5 up.
    HWN808
    HWN808
  • Who's Online   6 Members, 0 Anonymous, 729 Guests (See full list)
    • I can relate. 3 years ago I did that on my Avalanche. I was sore for a week. The only maintenance I do myself now is drop and fill on the transmission on my Honda’s. It’s just too easy. My yard work with my walks in the morning will be enough now I passed 70. The contributing factor is the heat in Texas. You just have to pace yourself.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
