Cold air intake for 2016 2500HD
https://dl.dropboxusercontent.com/u/55742651/Intake%20Testing/Intake%20Testing%20Results%20-%20Intake%20Testing%20Results.pdf
There is some real world data for you. These tests were done on a 2008 5.3L 1500 which has a more restrictive factory airbox and intake tube than the L96. The highest average gain was 5.8 HP/6.5 TQ. The only way a difference this small can even be detected is on a dyno. If you look at the MAP readings you will see they are basically identical. The highest gains were achieved using the factory airbox and just replacing the tube. I suspect the gains would be even less on the L96. If you like the sound, then go for it.
-Eli
Intake Testing Results - Intake Testing Results.pdf
  • Replies 36
All I was saying is that you do gain something. And most of these kits are just more direct tube to get the air into engine more efficiently. I'm not saying anyone is right or wrong. Any way you look at it if you know anything about way engine works.. More air in and expelled out will benefit more hp and torque whether it is minute or not.
That being said.. I can't get one anyways because not made for my truck yet.. Lol
I just replaced air filter with AEM high flow and kept old one for backup. They really did build these trucks right.. Right from factory
Im sorry, thats just not true. It is proven it does increase performance while increasing air flow. The factory setup has restrictions to keep mpg down, and thus performance down as it has for generations. And I like the sound, if you dont..then dont buy it...lol
Not true - do some research here. BB did some testing, the factory air box is second to none. Add a MIT, keep the AC filter and box and you are all set.
-Eli
attachicon.gifIntake Testing Results - Intake Testing Results.pdf
Nothing substantive that would cause me to shell out money to change the stock system. Torque numbers remained relatively flat. And torque is what does the work. HP did change, but nothing substantive. Something is going to have to make major changes beyond single digit HP to get me convinced it is worth the money.
I got the exact sound I want from my L96 just by replacing the trash can muffler with a Magnaflow. Nothing else. No change in any of the pipes. That was done purely to satisfy my desire for a deep, throaty sound but still not sound like I am at a Sturgis motorcycle rally.
That test is for 2008 5.3
I have 2016 6.0
  • 3 months later...
  • 3 weeks later...
The 16 k&n is completely different part number.. the 2015 6.0 k&n has a port for a humidity sensor ... k&n finally produces one for the 2016 2500hd 6.0 gas
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,301 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
