Transmission Slip
I am just wondering if anyone else has had a similar problem...
This morning, after dropping off my little girl at daycare, I took off from the daycare parking lot not pressing the gas too much since the roads were wet, between 2-3 gears (I think) it felt like it slipped, I could hear the engine rev between gears. A friend of mine said he thinks it is normal because of the new software to try to smooth out shifts?
I should add I have about 4k miles on it and it has happened about 4 times.
I have a 2015 Crew Cab Denali 4WD 1/2 ton with 5.3 and 6 speed tranny.
thanks all
Could be 1 of 2 things. There is something with this transmission where it requires an air purge. The first time it shifts from 2-3 it runs a purge cycle which must be opening another solenoid somewhere causing it to not lockup solid in 3rd. It will shift, do the air purge, then the RPM drop again as it finally makes it to 3rd.
It could also be a flare. Mine has had in intermittent issue where if I park and shut the truck off so that I do not need to use reverse to go again, sometimes when restart and go directly to drive it will flare the first time when it shifts from 2-3. When it shifts from 2-3 it disconnects from 2, revs the engine 200 RPM, then puts it in 3rd.
Mine does this. Most of the time in tow/haul mode. I wasn't too concerned because it's only happened about 8 times in 30k
Andrew it happened to me just like you said, I backed into the parking space so when I left I just dropped in D and took off. I guess it is nothing to be concerned over then?
I wouldn't say that it is nothing to be concerned about. The first time it happened to me I had my foot to the floor, it flared at red line. I explained to the dealer exactly how to reproduce it, but I think only 10% of that got through. They replaced the transmission anyway after the GM field rep looked at it. Transmission #2 started it again at 2000 miles, but is not as reproduce-able. Transmission #1 did this about 90% of the time when it was set up in the sequence to do it, #2 is about 5%. Now I am stuck with it, my dealer is telling me everything is normal, the clunking the flaring and the horribly slow shifting, and they will not even look at my truck anymore. GM is not much help either, they keep telling me to take it back to the dealer. I am going to dealer #3 later this week, but all I can reproduce now it the severely delayed downshift along with it going from 4th to 3rd to 2nd when I request a downshift. Why can't it go from 4th to 2nd?
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • First time it really happened to me was when I was 69 yrs old and I was called "Old Timer" by a complete stranger. Then in rapid succession came the aforementioned "Old Man" and my favorite of all "Pops".
    • Yea that's pretty normal to be off a few degrees after sitting.  Usually 2-4 degrees from say a weather app or thermometer.  I've seen it a bit more if you are parked facing the sun too when its really hot out.
