My truck is at the dealer and they can't figure out what is wrong???? It seems to me that it is the infamous rear end clunk from reading similar issues on the Internet. But they have given up on this being the issue after greasing the slip yolk. It's all the same symptoms people have expressed with that particular problem. A clunk when coming to a stop, occasional clunk while accelerating from stop, and the feeling of being rear ended at a complete stop. The dealer feels they have exhausted all possible causes of this issue but cannot find the problem. I was just called to come pick up my truck because they cannot figure it out and because I only have power train warranty left they don't want to charge me for the next steps in the search??? I worked for BMW and when this type of stuff would happen they would fly specialist to that dealer to diagnose these ghost issues. They did not just give up after 3 days and tell there customer to come pick up there unfixed/ undiagnosed vehicle. What do I do????
If you have a fair amount of miles on the yoke, dry, it could be worn.
Replacing it may be a remedy.
supposedly it's the differential and is normal (don't agree) my opinion is the leafs, and when they are loosened and the tension is release and then reset the noise goes away for awhile. it was suggested to buy bushings, but i always thought it was insane to have to do this, or any of the other things that i have to do to an over 65000 k truck.
This may not help your situation, but when my transfer case digested itself at around 140,000 miles, it was too far gone to rebuild so I got a new one. Prior to that I had the famous drive-line clunk, and it was pretty bad. Since the t-case replacement, the clunk is gone. I didn't really notice it until I had the truck back for about a week, then it dawned on me how quiet it was starting out from traffic lights, etc. I never did go back to the dealer and talk to them about it, just figured I was ahead of the game. I have put 20,000 more miles on it since then, still tight, no clunk, no jerking.
My truck is an earlier series, 2006 Sierra SLT.
I'm having the same issues with my 08 Crew with just 37k! I brought it to a dealer and they just blew it off. It is something in the rear end. Even at a stop it clunks like i just got hit! its driving me nuts! I've had GM all my life and my previous one was a 94 Z71 that never had a clunk....and no air noise in the rear cab. GM has to know of this problem just won't fix it!
Hello chevyguy69,
Thank you for being a loyal GM customer over the years. I regret to hear you are experiencing a clunk in your vehicle and would like to look into this situation with the dealership for you. If you would like my assistance please private message me with more details.
Best,
Julianne M.
GM Customer Care
Sara (2001 Z28) does this also, on de acceleration and from dead stop to acceleration. I had the rear end shop who changed gears (made clunk sound before and after gear swap) tell me "that it is normal for GM rear ends to do this, and it will not damage anything". This advice was given to me 14 years ago, and Sara has "clunked" ever since. I have not had any issues with the rear end other than to replace the pinion seal (an option on all GM cars).
I find it hilarious that GM customer service offers a hand of help to you ( chevyguy69) but has no input on this feed or is in any way helpful to the actual question of what is going on. ??? This seems to be a common issue people are having and dealerships have no clue on how to deal with it. I must say my service advisor has been very attentive and professional but he is at a loss after having 4 techs look into the situation.
