15GMCSLT Posted May 22, 2016 Posted May 22, 2016 (edited) Ok guys I was going to replace the door handles in my 2015 Sierra Crew Cab. I bought it used and it's an SLT. Previous owner switched the chrome to white and I wanted to go back chrome. After getting the front two done, I went to start on the rear. Both plugs were missing first off, and also the torque screws had been replaced with a damn sheet rock screw. "PISSED"!! Apparently the previous person backed them out to far and decided to just use any screw he could find. O, and the rubber seal that goes between the handle and door is missing. Does anyone know of the part numbers and do you know where to order online? (2) oem rear door handle screws (2) black plugs (2) rubber seals that go between handle and door. Thanks for the help everyone!! Edited May 22, 2016 by 15GMCSLT
martha3065 Posted May 22, 2016 Posted May 22, 2016 13578681 for the rubber seals. Not sure on the other two parts. http://www.gmpartsdirect.com/auto-parts/2015/gmc/sierra-1500/slt-trim/5-3l-v8-gas-engine/body-cat/rear-door-scat
15GMCSLT Posted May 22, 2016 Author Posted May 22, 2016 Thank you martha3065 that helps so much. Sent from my iPhone using Tapatalk
NWarrenZ71 Posted May 22, 2016 Posted May 22, 2016 Which white are they? I'd like to switch the chrome ones on my 16 slt to white. Sent from my iPhone using Tapatalk
15GMCSLT Posted May 23, 2016 Author Posted May 23, 2016 Summit White Sent from my iPhone using Tapatalk
15GMCSLT Posted May 23, 2016 Author Posted May 23, 2016 (edited) Well I've got a little information from local gm dealer. The black plugs are 13500936 $6.40 The rubber seal/gasket is 13578681 They are telling me that the handle base/bracket contains the screw and nut needed for assembly. $30 a side is expensive for a nut and bolt. Looks like part #'s 13592466 (L) and 13592465 ® Sent from my iPhone using Tapatalk Edited May 23, 2016 by 15GMCSLT
NWarrenZ71 Posted May 23, 2016 Posted May 23, 2016 Summit White Sent from my iPhone using Tapatalk If they are in like new condition, I would be interested in buying them from you. Sent from my iPhone using Tapatalk
15GMCSLT Posted May 23, 2016 Author Posted May 23, 2016 (edited) If they are in like new condition, I would be interested in buying them from you. Sent from my iPhone using Tapatalk I have someone ahead of you, but if something changes I'll let you know Sent from my iPhone using Tapatalk Edited May 23, 2016 by 15GMCSLT
TJay74 Posted May 24, 2016 Posted May 24, 2016 If you pull that door panel the inner nut they lost will be in the bottom of the door panel.
15GMCSLT Posted May 24, 2016 Author Posted May 24, 2016 If you pull that door panel the inner nut they lost will be in the bottom of the door panel. The bolt wasn't their either. Sent from my iPhone using Tapatalk
15GMCSLT Posted May 24, 2016 Author Posted May 24, 2016 Parts are in and the screw and nut are part of this as described above. They are not sold separate. Sent from my iPhone using Tapatalk
15GMCSLT Posted May 25, 2016 Author Posted May 25, 2016 Well here is the mysterious nut and bolt for the door handle. The new parts that came in had an extra set that I don't need. You still have to pull the door panel to instal these. But have have extra if anyone is interested. Sent from my iPhone using Tapatalk
NP37 Posted January 18, 2019 Posted January 18, 2019 I just ran into the same situation, except I was the one to back out the screw... the nut inside also fell and now I'm SOL. How difficult is it to remove the door panel and replace? I've been looking for videos, but haven't been able to find any. Thanks!
imiller1974 Posted January 18, 2019 Posted January 18, 2019 Video's all over Youtube for door panel removal.
