2015 Silverado Apparently can't Tow a Camper!
Well, I've been a happy owner for 11 months and 21k miles, but no longer. Started on our family vacation with our camper in tow (6100 dry weight, 7600 loaded) and made it two hours into the 7 hour trip before my AC went completely out. Made the remainder of the trip with the windows down on mostly interstate and 3 kids....not fun. Finally make it to our destination, unhook, and spend the night.
Get up this morning to run to the store and the truck starts shaking violently, throws the flashing check engine light and a solid traction control light. No idea what's going on (other than an apparent misfire issue and a blown AC), but now I have to take my truck to the dealer while on family vacation and hope it can be fixed by the time we leave in 5 days...then hope we don't get left stranded on the way back. Probably going to have to get a rental car as well, although I'm hoping for a loaner. What kills me is I bought the truck primarily as a tow vehicle for a camper!
Sorry for your troubles, but it's a mechanical item. Things can happen. I've pulled my 6,000 travel trailer with my Silverado several times now without issue. One trip was over 2hrs away and I had to go up into the mountains to get to the campground.
At least it's still under warranty and can be fixed. Good luck. Let us know what the problem ends up being
Good morning volrus,
I am sorry to hear you are experiencing these concerns with your Silverado. I apologize for any inconvenience this has cause and hope it has not spoiled your family vacation. Has the dealer been able to diagnose your truck yet? I can reach out to them on your behalf to see if there are any updates on your vehicle.
Best,
Julianne M.
GM Customer Care
Crap happens and it happened to you. Plenty of people towing with their trucks on here and no problems. Could have easily happened with another brand of truck.
Sorry about your bad fortunes mate. Good luck. Was is the closest dealer to you ? If it doesn't start they can tow it
Thanks Julianne. Unfortunately it doesn't sound like a diagnosis has been made today. They figured out the AC issue, but sounds like they have no idea on the engine other than "we think it's an internal issue". They said they are looking into it, but don't want to take the engine apart in fear of me not being able to drive it back when we leave on Friday. He was thinking if they could get it drive able then I could take it to my local dealer I guess. I explained that it basically has to be fixed because it has tow my camper back home 7 hours. He didn't sound very reassuring. The dealer is Preston Hood in Fort Walton Beach, FL.
Another update. Header has to be taken off to get to the problem. They said it might be a lifter. Have to admit, I'm pretty disappointed. However, it sounds like they will have it done on Thursday.
If it's just a lifter then you should be OK. That seems to be pretty rare on these new engines. Hope they can get it 100% for the trip home for you
In all seriousness, did I push the truck too hard? It just makes me sick to think they are ripping my engine apart after only 21,000 miles.
No you didn't push it too hard, this is a truck that has sold over 1,000,000 trucks of since the new body style came out in 2014. Parts failures happen, that is why there are 5yr/100k or 5yr/60k mile warranties on them.
don't feel bad...my '13 Silverado was at 16k when it started knocking, by 18k they had the engine in pieces on the floor.....replaced the #8 Piston, and it was fine for another 8k, then started to knock again....truck went bye bye after that....just luck of the draw
Verdict is in. The AFM lifter broke. It's being put back together now. I hope this is the last broken lifter!
Thought I would give another update. Turns out the lifter wasn't broke, it was just stuck. The solution was to replace the lifters in the left bank. I assume getting stuck is better than breaking?
Also, the AC hose actually split thus causing all the freon to leak out. They said it's a fairly common issue because GM tends to put them on too tight in the factory.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 452 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
