Hey all, new owner to a gorgeous looking truck! I honestly love everything about it... Except how it drives...
900 miles on it and it shifts like garbage.
Coming to a stop at a stop sign or light get a big clank and jerk. Happens 65% of the time, especially after warmed up. Also has a 25-30% chance of hard up shift when accelerating with a similar jerk. RPMs rev up then shifts with a jerk.
Went to dealer and explained issue. Waited almost 2 hours for them to take a 10 minute test drive down the road for them to come back and tell me they couldn't reproduce the problem. Upon questioning the test driver, he explained to me that there was too much transmission fluid (overfilled) and also said there was air pockets in the transmission.... Yea... Ok
He also told me he never drove the new 8 speed tranny silverados so he's not sure how the shift should feel, I told him well it definitely should not slam gears or jerk. He said he drained some fluid and released the "air bubbles" so it should be all set and if I have any more issues to bring it back.
Drove it home, it happened every time I came to a stop.
I'm afraid of the incompetence of the mechanics at this dealer; to try to tell me it's "overfilled and has air bubbles" as to the leading cause of slamming shifts... It's a brand new truck has 900 miles on it, bought it a month ago.
I see plenty of people having issues on their 15-16s with this issue and wonder has anyone had any type of resolution? Why is my brand new $60k truck already in need for transmission service?
Owned a 97 C2500 and a 00 K3500 and never had an issue with transmission even with almost 200k miles on each of them.
Please help!
Thank you!
please read my thread completely, it has all the info on what the dealership "actually" did, there is the transmission fast learn, there's a relearn procedure, and now they've determined to replace the valve body with TCM. So "airbubbles" has nothing to do with it. Just make sure you get EVERYTHING documented, and ALWAYS ALWAYS take the transmission tech or lead tech with you on the drive and show them what it's doing.
At this point, like I mentioned when I PM'd you, deal with the GM Executive Liaison, whose contact info I gave you and go that route.
900 miles on a truck that needs around 1500-2000 miles for all of the transmission adapt tables to get sorted out. My 2016 All Terrain had firm shifts and weird shifts as well, they pretty much went away by around 1500 miles or so.
Thanks for all the information, however it's not just a "hard shift" it's a slam/jerk and you can hear the transmission slamming gears, not just feel it. That's normal?
These transmissions are filled at the transmission assembly plant and normally need no addition/reduction of fluid. On occassion I'm sure it's possible that the vehicle assembly plant might have a need to add/reduce fluid, but as a rule this should be uncommon. Your dealership talked about an "air bubble", there is no "air bubble". If the trans was overfilled it's possible it could create a foaming condition or if underfilled it could cause the lack of suction of fluid but both of those conditions should be extremely rare or non-existent if the oil level is set correctly. Since they removed fluid, a practice that should rarely be required, perhaps you should have them or another dealer recheck the oil level and then adjust it as necessary. It's unlikely, but possible that they removed too much and not that is further adding to you harsh shift concerns.
Trust me I know what you are dealing with. It's not an oil issue, it's not an air bubble issue. It's a combination of a mechanical/programming in the TCM issue. Either one or the other or both. Email that person I gave you the contact information for, and they should take care of you brother. The slamming is not normal, I questioned myself as to wether it was normal for these transmissions to do what it was doing in our trucks and finally I got enough confirmation that it wasn't.
I completely agree as to the fact this isn't the issue. After the one trip doing the transmission fast learn to adjust the clutches that were causing the harsh shift and that didn't work, straight up valve body and TCM right from higher up GM. I think they know that they are some harsh shifting transmissions out there and now they are realizing they actually need new parts or a new TCM
I don't know about the 8 speed, but I wasn't happy with the way my 6 speed shifted when it had the same mileage, so I removed the negative battery cable for about 30 min. This reset the transmission computer and it settled down after that. It did take about 2000 miles to completely smooth out and now (at 6000 miles) is just as smooth as the 6 speed in my old 2010.
Yes, there is an air bubble, except it is not inside the transmission.
  • 5 months later...
I just had my torque converter replaced and they reset the TCM. So I am not at square one. when the truck was new I had downshift clunks that went away, but no hard shifting or noises. Now it slams from 1-2 and 2-3 and makes a noise that sounds like a manual tranny with b ad synchros.
did yours do that? and it went away after 1500 miles?
I have a 2015 silverado. It has been doing that since i bought it. Now i have 40k miles and i have been to 4 different dealers in 4 different states. And every one of them said it is "normal" though i dont know officially because im not tearing apart my truck. But gm is known to have issues with the limited slip diffs. Its a largely known issue. So considering that they already put out an update for my 4x4 engaging on its own it makes it hard to tell the cause and the issue. I am under the assumption that the faulty diff has led to my giant clunking and improper shifting. Because my issue started with just mild clunking. It has evolved to my transmission slipping, the clunks now jerk my whole truck. And if the roads are wet after coming to a complete stop my truck loses all traction in the rear and i slide everywhere. I have also noticed while coming down a parking garage that the back of my truck was jumping as i circled down to the bottom floor. So i think the problem started in my rear diff. And has escalated to much more than that since the mechanics at all the dealers i have been dont seem to have any mechanical aptitude.
just ran to Lowe's, chirped the tires twice slamming into 2nd while accelerating. not cool....
  • 2 years later...
I purchased a 2016 about six weeks ago. The transmission shifted hard from 2nd to 3rd most of the time and felt like it did not want to down shift alot of times. Took to a transmission shop I trust and they are upgrading the thermal bypass valve and reprogramming the TCM with a custom program. ( be aware that this will void your warranty). If I have any issues with the drive train I will have to have the TCM set back to factory before sending it to the dealer. I have also had diff issues, my tires spin all the time in the rain and at one point after the tires spun the left rear locked up. Had to stop and backup to free it up. (Sucks that I am not enjoying my new truck!)
  • 6 months later...
Has anyone had their transmission rebuilt because of this?  Mine is currently in the shop for the 3rd time and now they are saying "multiple internal failures".  They want GM to do a full replacement, GM says no - only will authorize a rebuild.
Any thoughts on this?  Is a rebuild sufficient?
  • 3 weeks later...
has anyone resolved this issue? because my 2016 high country is shifting hard from 1-2 going downhill and jerks going uphill. I don't want to go to a million different dealers to eventually find the solution. so if anyone has any good information please let me know what y'all did to get the problem resolved.
  • 1 month later...
    Afennell19
    Afennell19
  • Who's Online   0 Members, 0 Anonymous, 876 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
