Just sharing this with people who don't want onstar communicating with your vehicle. The fuse feature in my case has not worked. Not on the Silverado or the new corvette. The vehicle is still trackable. However there is good news. There is a fairly simple mod that will let you retain your airbags and all the other features that are shut down by pulling the fuse.
Step 1 pull of the plastic trim surrounding the radio.
Step 2 remove the 4 7mm screws around the radio.
Step 3 pop out radio.
Step 4 locate onstar box and remove the 2 white plugs and maroon antenna plug.
Step 5 pop out module and take it to your work bench.
Step 6 remove the Allen or star bits on the bottom of the module. There are 5 I believe. Pull the casing apart.
Step 7 pull the board directly out towards you.
Step 8 you will see a small board held in with 3 black star bits it has the antenna plug attached to it. The motherboard was originally plugged into it. Take the 3 small star screws out remove and toss it in your pile of spare parts. Put it all back together.
Step 9 it's now impossible to be tracked by onstar or law enforcement. This works for the new c7's as well as the new trucks. You now have no warning lights. You get to keep all your airbags and traction. You do lose nav unfortunately. Onstar and the rest of the truck believe will function as normal. Push the onstar button twice and it will tell you the call can't be completed at this time. This mod takes about 8-10 minutes.
So your in dash Nav is disabled from this?
My nav is still working. Truck still tracks on the map. However the nav icon has a slash thru it. Mod simply deletes onstars ability to communicate with the vehicle. The color of the antenna plug indicates a cellular antenna. However even with just the antenna unplugged the unit can still receive and send data. So that's why the entire cellular board needs to come out. I'm unsure why the nav icon has a slash thru it.
Edited by Bigbadcj
  • 3 years later...
So I just pulled mine out of my 2018 Danali which has two different antenna ports. What two antenna's did I unplug? Also I just to confirm, with this removed onstar will no longer receive data from my truck about location or speed or anything else but I will still be able to make and receive phone calls from onstar?
  • 1 year later...
  • 2 years later...
  • 1 year later...
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
